Re: UVI Xtreme FX 2 updated to 1.0.3
Yeah... really strange that Portal would happily let me continue running 1.0.2 until January of 2025 and THEN notify me of the update.
I'll be interested in UVI's reply as to why despite running UVI Portal over a hundred times in the last six months, only today it notified me that I needed to update to 1.0.3? I may start checking at the website and not rely on UVI Portal anymore. That's just ridiculous.
Indeed brother.
DDMF Plugin Doctor updated from 2.3.7 to 2.3.8
https://ddmf.eu/plugindoctor/
2025/01/14: v2.3.8 some scale/value display improvements
APU Software Updates
APU Loudness Series updated to 3.2.7
https://apu.software/download/
Version 3.2.7
Fix loudness types enable/disable not updating visually (limiter)
CPU optimization for component refreshing
A.O.M. Plugin Updates (including Invisible Limiter series)
https://aom-factory.jp/download/
Looks like there were a couple of releases that I missed. (I own Invisible Limiter G2).
Version 1.18.1 (2025-01-14)
BugfixesChanges
- [CLAP] Potential crash bug where plugin I/O precision is set to 32bit floating-point in Studio One. This problem was introduced in version 1.18.0. – fixed
- [CLAP][Windows] Wrong window size bug in HiDPI environment. This problem was introduced in version 1.18.0. – fixed
- [macOS] Potential wrong color. This problem was introduced in version 1.18.0. – fixed
- [Nu Compressor] Blank background when user collapses right panel. This problem was introduced in version 1.18.0. – fixed
- [VST2][Invisible Limiter G2, Nu Compressor, tranQuilizr] Wrong plugin window size when user expands/collapses panel. This problem was introduced in version 1.18.0. – fixed
- [VST2][macOS] Wrong content draw position in Ableton Live. This problem was introduced in version 1.18.0. – fixed
- [VST2][Windows] Plugin window was incorrectly resized when user moves detached plugin window between different DPI screens. This problem was introduced in version 1.18.0. – fixed
- [VST2][Windows] Plugins are not scanned in Samplitude, for Samplitude shows host VST version 2.3. This problem was introduced in version 1.18.0. – fixed
- [VST3] Knobs and sliders are rattling in Ableton Live. This problem was introduced in version 1.18.0. – fixed
- [VST3][macOS] Crash bug when user removes VST3 plugin instance in FL Studio. This problem was introduced in version 1.18.0. – fixed
- [VST3][Windows] Potential wrong window size when user slowly moves plugin window between different DPI screens in Cubase and Reaper. This problem was introduced in version 1.18.0. – fixed
- [VST3][Windows] Crash bug when user replaces VST3 instance by VST2 instance of the same plugin in FL Studio. This problem was introduced in version 1.18.0. – fixed
- [All Plugins] Reset button in plugin menu bar performs plugin state reset immediately.
Version 1.18.0 (2024-12-27)
New PluginImprovements
- Invisible Limiter LL: Same to Invisible Limiter, but fixed to LATENCY=LOW setting. Unlocked by Invisible Limiter license.
Bugfixes
- [VST3, AAX-Native, AudioUnit] [Invisible Limiter, Invisible Limiter G2, Invisible Limiter G3, tranQuilizr, tranQuilizr G2] Supports up to 64 channels.
- [AudioUnit] [Invisible Limiter, Invisible Limiter G2, Invisible Limiter G3, tranQuilizr, tranQuilizr G2] Add countermeasures to Ableton Live’s behavior that it selects maximum channel count for explicitly-declared surround channel configurations. As a side effect, plugin’s CPU load gets reduced.
- [Nu Compressor] Improve visibility of VU/Peak switch.
- [Track Symbiosis] Add output peak meters and reduction meter.
- [Invisible Limiter, tranQuilizr G2] Update GUI with Hi-DPI images.
- [tranQuilizr G2] Add spinner controls to band palette.
- [Track Symbiosis] Available in VST2 format.
- [Windows] Improve GUI drawing performance.
- [tranQuilizr G2] Show band type icon under EQ points.
Changes
- [All Plugins] Plugin crashes or becomes unstable when user entered il-formed text to text field in generic UI provided by plugin host. – fixed.
- [Track Symbiosis] Cubase 14 shows “Cubase has become unstable” message when user closes plugin window while “Graph Range” popup menu of Track Symbiosis is shown. – fixed.
- [Invisible Limiter G3] Audio glitch appears when user operates MS Balance knob very quickly. – fixed.
- [tranQuilizr G2] Monitor channel settings were not saved to project. – fixed.
- [tranQuilizr G2] Channel knobs disappear when user changes bus configuration dynamically in Studio One. – fixed.
- [Nu Compressor] Current program does not return to Standard Nu Compressor program when reset. – fixed.
- [Track Symbiosis] Plugin may fall into abnormal state under following condition: HF button is enabled, non-silent signal is fed to side-chain and user frequently toggles side-chain availability.
- [All Plugins] Migrate from JUCE Library to our own audio plugin framework.
- [Track Symbiosis] Unify level meter’s scale.
- [Invisible Limiter] Always behaves as if LATENCY=NORMAL is set.
- [All Plugins] GUI scaling becomes 10% step.
Well the plot thickens. I heard back from UVI support (see below) and it indeed looks like version 1.0.3 of the Xtreme FX 2 library was in fact released yesterday. I think what happened is that they did not update the release date on the website, only the version number. I'm going to write back and let them know. So if you DO have Xtreme FX 2, you might want to launch UVI Portal and update, or download 1.0.3 from their website and ignore the date for now.
In any case this has been the most well-vetted update announcement I've every posted here.
Awesome; thanks James!
I can confirm that they did indeed update the date on the download page. It went from March to April when we now know for-sure it should have changed from March to Jan this year.
I relied on the published date of course and checked the creation date of the 1.0.2 file I had and indeed it was March last year.
You've actually solved a little issue I had - why had I somehow missed the April update? You posted the fact that the new version had dropped, I checked the DL page and lo and behold, as I said, there it was and I was left scratching my head as to how I missed it all those months ago. Following that of course I "PSA'd" the apparent fact, according to that page, that it dropped last year.
So in summary, if I've got this right, we now know everything except for an official explanation as to why the DL page is wrong. It's obviously human error, one might assume, and one that ought be fixed if for no other reason that I'm sure others will be scratching their heads too when they discover that they apparently missed the update.
Good on you and good on UVI for being transparent, as always. Thanks again brother.
IK Multimedia SampleTank updated to 4.3.4
SampleTank 4.2.4
Fixed an issue where the plugin UI would appear blurry on Windows with high DPI scaling
Fixed browser not retaining favorites and search text when closing and re-opening the UI
Fixed a crash when using the Flexi Amp effect at 96 kHz
Fixed a crash when the library rescan process completes and the plugin window has been closed
Fixed a potential crash at shutdown
Fixed an issue where Syntronik Multis with custom waveforms would not load properly
General reliability improvements
Re: IK Multimedia Syntronik 2 updated to 2.1.2
Looks like they got this FIXED now. IK Product Manager now downloading the correct 2.1.2 installer.James Steele wrote: ↑Thu Jan 16, 2025 6:33 pm IK Multimedia Syntronik 2 updated to 2.1.2
UPDATE: IK Product Manager seems to be downloading version 2.1.1 instead. Tried multiple times.Changes from version 2.1.1:
Fixed an issue where saving a DAW session would not save custom waveforms selection
Fixed an issue where duplicating Syntronik instances wouldn't retain custom waveforms
General reliability Improvements
Steve Slate Drums updated to 5.5.8
Update via Steven Slate Audio Center app.SSD 5.5.8
- Fixed the bug with the scrollbar not appearing in the song constructor part of Groove Al
Steinberg Spectral Layers 11.0.50 updated to 11.0.60
SpectraLayers 11.0.60
January 23, 2025. We’re happy to announce the availability of the SpectraLayers 11.0.60 maintenance update. This new version introduces several issue resolutions and improvements throughout the application.
Improvements and New Features
• Keyboard shortcuts to change the tool brush shape and units have been added.
• The Bridge plug-in for Pro Tools now supports handles.
• Tooltips with the full file path are now shown when hovering over recent projects in the home screen.
• View > Time Unit > Tempo and Time Signature dialogs have been improved.
• The time that it takes to display a long transcript has been reduced.
• An error message is now displayed when using the Unmix Transcription function with an unsupported CPU on Windows.
Stability and Performance
• A memory leak when downmixing the channel view or when soloing a channel has been fixed.
• An issue with mouse events and the mouse cursor with Pro Tools in ARA mode has been resolved (macOS only).
• An issue with the Pro Tools Bridge plug-in preview has been resolved (macOS only).
• The Transfer tool no longer causes the display to blink when one layer is soloed.
• Using Project > Reformat now keeps all project settings.
• Tooltips now always show up with Pro Tools in ARA mode (macOS only).
• Unmix Multiple Voices no longer freezes during processing.
• When working with SpectraLayers as an external editor for DaVinci Resolve or other host applications, all edits are now applied correctly (Windows only).
• Voice DeNoise now uses the reduction ratio percentage correctly when used with Background: Music.
• Edit > Delete Time/Insert Time/Crop Time shortcuts are now accessible in the preferences.
• Layer > Ungroup now properly selects layers after ungrouping.
Relab QuantX 2.0
For those interested, QuantX has been updated.
https://relabdevelopment.com/quantx/
2013 Mac Pro 2.7 Ghz 12 Core Intel Xeon_128G Ram_OSX 12.7.6_DP 11.32
- corbo-billy
PIGMENTS in version 6 _
Arturia update Pigments to version 6.0.1.
https://www.arturia.com/fr/products/sof ... s/overviewNew Granular Scan
_ New Grain Size Continuous Ratio
_ New Round Robin & Random sample assignation per Key or per gain
_ BitCrush Decimate mode now allows to choose between 2 downsampling colors
_ Sync All has been added to Density rate type
_ New Cluster Filter: From classic formant filtering to modern bass sound design
_ New LoFi Filter: Per voice downsampler coupled with pre and post filter
_ New revision of the Multifilter:
_ Renamed Classic Filter
_Added Input Drive
_ Added three All-pass filter modes
_ New Analog resonance mode, which distorts the signal when resonance is high while preserving the low end
_ New Vocoder Effect: For color-bass sound design and hollow vocal sounds
Effects improvements:
_ Multimode filter: Added All-pass filter type and analog resonance mode
_ Distortion: Added All-pass filter type and analog resonance mode
_ More parameters are now modulable
_ StereoPan has been renamed "Panner" and a "Pan" parameter has been added
_ New Random modulator: Simple yet powerful and versatile random source
_ New Voice Modulator: A controlled source of randomness providing different modulation values per voice in the spirit of vintage synths
_ New Envelope follower: Tracks the amplitude of any point inside the signal path and turns it into a modulation
_ New Function V2:
New preset browser
New S-curve
New Smooth parameter
New grid mode
Rework of the operation and retrig modes UX
New Browser for Samples, Wavetables and Noises:
_ Factory samples and wavetables are now sorted into new categories
User samples and wavetables are now separated from the factory content, under the Folders tab
_ Quick Edit V2: The quick edit workflow now supports the assignation and edition of sidechains using drag & drop and the _ _ Quick Edit pop-up
_ New Global Transpose section in Keyboard panel (octave and fine tune)
_ New Preset recommendation system allowing to suggest similar sounds from the library to the selected preset
_ Revamped filter selection pop-up
_ New Content:
_ 100 Presets
_ 53 Wavetables
_ 97 Samples
_ 60 Noises and Transients
_ New tutorial
Sound Engine:
_ Filters clicks have been reduced, particularly on digital filters
_ Comb Filters algorithm is now smoother when tweaked and holds a better tuning in the high frequencies
GUI:_
_ The interface style and layout have been refreshed and improved
_ The interface and interactions of the keyboard panel has been improved
_ The interface and interaction of the filters has been updated
_ The UI and UX of the engine Tune and Output sections have been improved
_ The sample engine playback visual feedback is now polyphonic
_ The Distortion effect layout has been improved
_ The LFO layout has been improved
_ Improved parameters tooltips and descriptions
UX:
_ The modulation assign mode now features a toggle on the sidechains
_ Some default values have been changed
Bugfixes
_ Comb filter: no more clicks when changing modes
_ Filters: no more clicks when swapping filters
_ Amplitude Envelope's parameters no longer produce noise when modulated
_ FX Distortion no longer acts as a notch filter when doing parallel distortion
_ Formant filter's Q Factor has now cleaner modulations
_ Glide no longer jumps when Microtuning is enabled
_ Sequencer / Arpeggiator : First step now plays correctly each time
_ Fixed a bug where the interface was lagging with AMD GPUs
_ Tooltips and descriptions: Typos and various fixes
_ Various other GUI fixes
IK Mutlimedia T-RackS 6 updated to 6.1.2
• Pusher: renamed to Quad Saturator, session recall will be fully supported in the following DAWs: Reaper, Logic Pro, Pro Tools, Bitwig, Cubase, Ableton Live, Studio One
• Channel Strip X: improved stability of the editor on Mac Intel
• Mastering Console: added copy/paste snapshot between clips
• Mastering Console: added saving/restore windows size
• Documentation: updated User and Module Processors Manual
