Korneff Updates
Updates for WOW Thing, El Juan Limiter, Puff Puff mixPass, and Pumpkin Spice Latte
https://korneffaudio.com
PSP Chamber and EasyVerb both updated
Chamber updated to 1.0.1:
Changes:
Default preset as first on the preset list.
New:
Presets from Eenrico De Paoli and Andrzej Karp
Fixes:
Missing Miscelenious preset category solved.
EasyVerb updated to 2.0.1. I don't have this one, so not sure what the exact changes are.
Re: Korneff Updates
bayswater wrote: Mon Dec 23, 2024 12:12 pm Updates for WOW Thing, El Juan Limiter, Puff Puff mixPass, and Pumpkin Spice Latte
Thanks for this one! I just downloaded the installers for the two that I own: El Juan and Puff Puff.
Here's are the changelogs (as included inside the installer) for those:
El Juan Limiter
Version 1.0.5
12/16/2024
- remove annoying folder in Downloads
Puff Puff mixPass
Version 1.0.2
12/17/2024
Tokyo Dawn Labs Updates
Run TDR Collector app to update.
TDR Nova GE 2.1.6 updated to 2.2.0
2.2.0 Update
• Band Solo is now a parameter
• Graphics updated for hires displays
• Fixex shelf/bell Q recall bevaviour
• Fixed plugin resize mouse behaviour
• Fixed graphical glitches in Sonoma
• Wavelab montages: Fixed "*" not appearing after changes
• Various mouse logic and Ul improvements
TDR Limiter 6 GE 1.2.6 updated to 1.2.7
1.2.7 Maintenance update
• Fixed compressor "DRY AMT" showing no effect
• Fixed "*" not appearing in Wavelab montages after changes
• Fixed graphical glitches appearing in Macos Sonoma
• Improved support for hi-res displays
MiniMeters updated to 0.8.24
https://minimeters.app/
0.8.24 - Bug Fixes + Improvements
Released: Dec 23, 2024
This update is free for existing users.
Improvements:
• Windows: MiniMeters will now automatically to compensate for the selected audio device's system output volume when needed.
Bug Fixes:
• General: MiniMeters will no longer quit unexpectedly after some time when multiple pop-out meters are open.
• Windows: MiniMeters will no longer fail to open when the ASUS "AI Noise-Canceling Microphone" is present on the system.
• Linux: MiniMeters will no longer crash while displaying a tooltip on Linux when using Nvidia display drivers newer than version 535.
• Waveform: In the case where the Waveform module is popped-out, scrolling on the primary window will no longer cause the Waveform's Speed setting to change.
APU Software Updates
APU Loudness Series updated to 3.2.2
https://apu.software/download/
Version 3.2.2
Fix custom default preset not loading for new plug-in instances
Fix history visualization under certain conditions
Move buttons to upper-right of group (limiter)
APU Loudness Series updated to 3.2.3
Version 3.2.3
Fix look-ahead in certain scenarios
Fix look and feel for some dialogs
Tokyo Dawn Labs Molotok & Molot GE updated to 1.0.6
1.0.6 Maintenance update
• Sonoma: Fixed graphical glitches
• Graphics: Improved hi res display support
Tracktion/Wavesequencer Updates
Hyperion 1.60 updated to 1.6.2
Theia 1.17 updated to 1.19
Run Tracktion Download Manager to update
IK Multimedia MixBox 1.5.1 updated to 1.5.2
What's New in v1.5.2:
Fixed a crash when the hosting track has more than 2 channels on the side chain bus
NI Battery 4 updated to 4.3.1
Version 4.3.1 2025-01-09
ADDED
Support for macOS 15 Sequoia
ADDED
Support for macOS 14 Sonoma
FIXED
"Missing Samples" window was not triggered in some situations
FIXED
Skipping "Missing Sample" could cause cells to remain blank
FIXED
Komplete Kontrol crashes Logic Pro X when closed if hosting Battery
FIXED
Project file including Battery instances increases in size every time it is saved (Cubase)
FIXED
Moving cell broken after missing sample has been relocated
FIXED
Vintage Sampler MP60/SP1200 modes do not affect output
FIXED
Saved kit missing from user section in browser after resave
APU Loudness Series updated to 3.2.5
Version 3.2.5
Fix saved look-ahead settings load error
Version 3.2.4
Component refresh optimization
Re: NI Battery 4 updated to 4.3.1
Post by Rick Cornish »
James Steele wrote: Thu Jan 09, 2025 1:38 pm NI Battery 4 updated to 4.3.1
Thanks for this, James!
When I opened Native Access, I also found these updates… depending on your subscriptions, you may have more or fewer updates available.
Screenshot 2025-01-10 at 12.55.10 PM.png (218.6 KiB) Viewed 2706 times
Kirchhoff EQ updated to 1.7.1
Not sure when this happened because it's a hassle to have to go to the Plugin Alliance site and compare version numbers of my installed plugs agains what's indicated in the manage licenses area of my account, but I had previously had 1.7.0 installed of Kirchhoff EQ and it's now 1.7.1. Not sure what the changes are.
Run the PA Installation Manager app to update.
Plugin Alliance Lindell 50 Series updated to 1.0.4
Not sure when this happened because it's a hassle to have to go to the Plugin Alliance site and compare version numbers of my installed plugs agains what's indicated in the manage licenses area of my account, but I had previously had 1.0.3 installed of the Lindell 50 Series and it's now 1.0.4. Not sure what the changes are.
