Kontakt 8.1.0 Update
Pretty big updated with lots of fixes:
Version 8.1.0 2024-10-21
KONTAKT IMPROVEMENTS.
ADDED
AAX Plugin migration is now available from Kontakt 6 and 7 to Kontakt 8
ADDED
New amp and stomp effects: Super Fast 100, Chainsaw, Kolor, Skreamer Deluxe
FIXED
Space bar did not get picked up by the DAW after a Tool has been loaded
FIXED
Crash when showing the Batch Resave dialog in default view
FIXED
Crash when restoring a ProTools project with a large number (>10) of Kontakt instances
FIXED
Previews continued to play after Tool or Leap presets were loaded from the Default View side pane
FIXED
Drag and drop to create an instance of Kontakt in ProTools brought up the Missing Content dialog
FIXED
Tool "Retrigger" and "Dyn Mode" macro knobs did not show values in Maschine/Komplete Kontrol or when automated
IMPROVED
Bass Invader amp can now process stereo signals
LEAP IMPROVEMENTS.
ADDED
More SendFX Delay and Reverb types
FIXED
Playback stopped if pointer is moved while playing
FIXED
Macro knobs on play page were missing hover states
FIXED
Issues after duplicating samples
FIXED
Snap functionality took points after the sample end and start into account when snapping in Auto or REX mode using Beat Machine
FIXED
Stuck latched notes in scaled mode
FIXED
Parameter labels were not drawing on Kontrol S MK3
FIXED
Changing audio device in Bitwig brought up the Missing Content dialog
FIXED
Changing the engine of any sample killed all current voices
FIXED
Replacing a playing latched loop led to a stuck note on virtual keyboard
IMPROVED
Perform FX and Macro FX toggles are now pinned to both Sound and Engine tabs
CHANGED
Snap mode now defaults to Grid
INSTRUMENT BUILDING AND SCRIPTING.
ADDED
KSP: SNIEPP_EQ_MODE_E_GRAND built-in constant
ADDED
API: set_zone_group command
FIXED
KSP: Regression with SEVENT_NOTE and SEVENT_VELOCITY built-in variables having random ## values in multiscript
FIXED
KSP: (N)RPN messages sent from multiscript did not reach instrument scripts
IMPROVED
KSP: NKS2 parameter groups can now have up to 48 parameters
KNOWN ISSUES.
KNOWN ISSUE Arrow Keys not working in Sidepane of Default View in some VST3 DAWs on Windows (Live, Cubase, Studio One)
KNOWN ISSUE
New Kontakt-related files types (NKL,NKT) do not open Kontakt when double-clicked in OSs filer/explorer
KNOWN ISSUE On macOS, Spacebar input to start/stop playback reaches DAW only at 2nd press if Kontakt plugin is moved via D&D
Softube Updates
I got notice that 4 Softube plugs I own have updates:
• Tape
• Weiss Deess
• Weiss MM-1 Masterming Maximizer
• Widener
I looked for a change log for v2.5.92 on Softube's site, but only previous version released on 10/8 was listed.
Addictive Drums 2.5 Update. Looks significant.
Addictive Drums 2 2.5.0. Oct 22, 2024
Our biggest update to Addictive Drums 2! A fresh new look with a modern interface focused on ease of use. Brand new features, performance improvements and bugfixes.
New improved interface
New Trig Gate effect
New compressor mode: "Boost!"
Improved EQ with spectrum analyzer
Beat Transformer more accessible
Help tips in the bottom bar
Bugfixes & performance improvements
UPDATE: Just launched this. Most striking thing is they seem to have really cleaned up the UI and preset browsing. I really like the look of the updated version. Funny how a UI improvement will make me more inclined to actually USE a piece of software. I may start reaching for this sometimes instead of SD3 which has been my go to. (Right click image below and choose to open in new tab to see full size. This as at 100% but I may bump it to 125%. Also has option for Open GL hardware acceleration, but not sure if I need or even should use that?)
Also I just noticed the gathering of usage information box is checked by default. May want to turn that off.
SSL Updates
SSL Updates
Just launched SSL Download Manager, and X-EQ 2 and FlexVerb have been updated. FlexVerb to 6.8.9 and X-EQ 2 to 6.7.2. I clicked the "i" but no update notes available. Other SSL plugs that I don't own may be updated as well.
Guitar Pro 8 updated
Changelog
Release Notes
8.1.3
Edition
After transposing, the display options of a chord are now correctly preserved
Fixes an input error when typing fast in the tablature view
Fixes an unwanted merge of tempo automations with the same value but different units
Fixes the loading of a sound automation in a specific case on opening a file
Scale diagrams are no longer deleted after changing the layout
Playback
Fermatas are now correctly played when the Audio Track is bypassed
Interface
Fixes the name of the “Saxophone Alto” template track
Fixes the tooltip value of the Pan Knobs
Fixes the display of the active sound
The Audio Fine Tuning dialog values are now correctly updated when switching documents
Fixes German and Chinese translations
Import / Export
Copying from Guitar Pro correctly creates again a MIDI file in the clipboard
Fixes missing notes in the MIDI file when Copying
Fixes the import of MIDI files containing negative ticks
Fixes the import of MIDI files with no “endOfTrack” event
Improves the import of large TEF files
Fixes an issue when saving on a disk root (Windows)
Audio Track
Improves the accuracy of the zoom
Fixes the cursor position when the editing score cursor is on an empty beat
Fixes the Undo/Redo of the Filter, Semitones and Cents buttons
When changing documents, the scroll position of the audio track is correctly restored
Miscellaneous
Ensures the auto-save is done in a local directory
Crashes
Fixes a crash on pasting on an empty file
Fixes a crash on importing a file containing invalid tremolos
Fixes a crash on loading an audio file
Fixes a crash on starting a second instance of Guitar Pro
Fixes a crash on using the “Play while editing”
Fixes a crash on tying notes
Fixes a crash on using the batch converter
Fixes a crash on opening a file containing fingerings
Fixes a crash on loading an XML file
Fixes a crash when scrolling the playback cursor
Fixes a crash on using the countdown
Fixes a crash on opening the Chord dialog
Fixes a crash on opening a mySongBook file after a connection
Fixes a crash on pasting from a closed document
Fixes a crash on editing from the Virtual Fretboard
Fixes a crash on using the graphic export
Fixes a crash on purchasing a mySongBook file
Fixes a crash on the multirest option is activated on an empty file
Fixes multiple random crashes on documents containing chord diagrams
corbo-billy
Re: Softube Updates
Post by corbo-billy »
James Steele wrote: Tue Oct 22, 2024 12:40 pm I got notice that 4 Softube plugs I own have updates:
• Tape
• Weiss Deess
• Widener
And also Bus Processor and Chandler Limited _
corbo-billy wrote:And also Bus Processor and Chandler Limited
Thanks. Yeah. I don’t own those so couldn’t see. I’m still having a terrible time with the Softube updater. Practically every other time I run it it gets stuck and I have to delete and reinstall the helper. Don’t know why, but it’s the most problematic updater app on my Mac by far.
corbo-billy
Yes and it' s never very easy to know the content (Release) of the updates.
labman
Post by labman »
James Steele wrote: Tue Oct 22, 2024 3:14 pm
Its HORRIBLE!!! :banghead:
Re: SSL Updates
James Steele wrote: Tue Oct 22, 2024 1:40 pm SSL Updates
Note to whom it may concern:
If you like to keep the installers, the individual downloads on the site haven't been updated yet:
https://support.solidstatelogic.com/hc/ ... nloads-0-0
I've been waiting several days. In the past I've emailed support and informed them but I'm not playing that game anymore; it's not my job to tell them how to do their job. :lol:
Vienna Synchron Player updated from v. 1.3.1748 to 1.1.1785
v1.3.1785 - October 23rd, 2024
Fixed
• Crash when opening Surround version
• Windows: Vienna Helper tool opened in Command Line
• Cubase on Windows: Slow GUI closing / crash when closing the session when GUI was
Improved
• Implemented Lok's workaround for AMD Zen 5 CPUs
corbo-billy
Audiothing Lines Feedback Multieffect
Changelog:
2024/10/24: Lines version 1.1.
- Added: Oversampling
- Added: Graphics Controls (Brightness and Contrast)
- Added: macOS 14 Sonoma support
- Improved: Pulse Sequencer host sync
- Improved: Preset browsing avoids loud clicks
- Fixed: Crash with samplerate lower than 44.1kHz
- Fixed: Random crash in VCV Host
https://www.audiothing.net/effects/lines/
UVI Falcon updated to 3.1.1
And damned if I can find a changelog for 3.1.1. There's no link in the info window in UVI Portal except to the manual.
UPDATE: "Release notes" link appeared today. Here's what has changed:
3.1.1
- Fix some issues and crashes related to the new Tag Browser
- UI tweaks in the new Tag Browser
- Can now use AND and OR operation for timbre tags
Looks like (at least for me) UVI Portal is still wonky and it downloads the Falcon dmg and tells you it has installed it but it hasn't. You have to go into Downloads folder and open the dmg file and then launch the pkg.
East West OPUS 1.5.4 updated to 1.5.5
No idea what changed.
KV331 Synthmaster 3.0.3 updated to 3.0.4
https://www.kv331audio.com/userarea.aspx
Again... can't find a changelog. Ugh...
