Hmmm... which ones? I'm doing pretty well here on Ventura myself.primeevolutionary wrote: ↑Tue Apr 11, 2023 1:51 pm There are still a lot of plugins that I use that are not yet ready for Ventura.
I don't understand exactly. Ventura plugins work on Apple Silicon Macs. They're both meant for AS Macs. Most of the plugins I had that were working on Monterey kept working when I went to Ventura, even though some of them weren't officially supported. That's just a CYA disclaimer for developers as sometimes there are incompatibilities that can sneak in with a new OS. But once they fix those compatibilities they should be backward compatible with earlier versions of MacOS.I had a question regarding silicon Macs: As these plugin companies release their Ventura plugins, do I still have to worry about whether a plugin will work on a silicon Mac?
If you're using DP, your primary plugin format is likely Audio Units. AFAIK, most Audio Units are Apple Silicon native now. The big hold out has been native AAX plugins for Pro Tools since Avid was slow to release an Apple Silicon native version of Pro Tools. Also when I mention a plugin is AS native, they're actually UB2 (or Universal Binary 2) which contain Apple Silicon code and Intel 64-bit code. They will continue to work on Intel Macs.Or, will every future release be a potential additional waiting period for silicon Mac compatibility until Intel Macs are no longer OS supported?
If you don't have it already, I highly recommend getting an app called PlugInfo on the App Store.
https://apps.apple.com/us/app/pluginfo/ ... 2949?mt=12
It's very useful at keeping track of your plugs and will show you which contain Apple Silicon code and which do not. It shows all formats: AU, VST2, VST3 and AAX.
