Page 5 of 6
Re: Best Plugins? TC powercore firewire?
Posted: Fri May 20, 2005 4:01 pm
by wonder
off hand, whats the price difference between the UAD and PCore Fwire?
Posted: Fri May 20, 2005 6:27 pm
by wonder
ok.
so...
Waves vs UAD?
Who wins?
Posted: Fri May 20, 2005 7:36 pm
by chrispick
Wonder --
I don't know if this'll help you or confuse you, but here are two variables to weigh in your decision:
1. Do you want EQs and compressors that will color your sound as you use them? Or do you want these tools to be as transparent as possible?
2. Do you have any needs for additional plugs that come with these packages? For example, if you'd like a decent amp sim or modulation effects or channel strip ability with your EQ/compressor/reverb pack, then that can influence your purchase.
In short, I'm trying to put your mix needs before the disparate opinions of others because all of the mentioned plugs do the same thing, generally speaking, but do it differently . And some ship with different side orders, if you will, which might appeal to you.
To give you a personal example: I like different compressors for different uses (and I'm by no means a connoisseur). For me, color-adding comps like VintageBurner can sound great on drums, bass guitar and organs, but transparent comps like TrackPlug are more suitable for guitars and horns.
Dig what I'm saying?
Posted: Fri May 20, 2005 7:50 pm
by wonder
i dig.....
mostly im looking for
1. a KILLER comp/limiter for vocals, drums, bass.
2. AWESOME reverb for vocals, drums
I do 90% acoustic instrument stuff (neo soul, r&b). SOME stuff with RMX drums and stuff....I dont do techno or rock so maybe that will help in helping me....?
Posted: Fri May 20, 2005 7:56 pm
by bralston
The following UAD-1 plugs will make you smile big time.
LA-2A compressor (Great for vocals, anything really)
Fairchild Compressor (Great for drums & bass, very characteristic sound)
Precision Limiter (Awesome transparent limiter for mastering mixes)
Plate 140 (just like using the real thing...awesome plate 140 sound, great for vocals and guitar, drums, etc..)
<small>[ May 20, 2005, 10:57 PM: Message edited by: Brian W. Ralston ]</small>
Posted: Fri May 20, 2005 8:11 pm
by chrispick
i dig.....
Okay. My two cents then...
Given the neo soul / R&B tip, I'd suggest the UAD-1 for EQ/comp stuff because it emulates the warmth of vintage gear. I take it you probably want "warmth" or "fatness" over, say, "shimmer" or "gleen," at least if you have to pick one over the other.
And, if you can afford it, get the UltraPak for the Plate verb (or pick it up a la carte later).
Oh, and if you want that "real room" verb sound, the best plug-in bet is probably Altiverb.
<small>[ May 20, 2005, 11:15 PM: Message edited by: chrispick ]</small>
Posted: Sat May 21, 2005 4:17 am
by dixiechicken
Wavearts at
http://www.wavearts.com/ makes a couple
of very nice plugins.
1: They sound good
2: They are reasonably priced
4: The cpu-drain is very low
5: You can download and try them out for 30-days
6: They are fairly easy to use.
Quite a few professionals actually use them -
including me of course.
Cheers: Dixiechicken
Posted: Sat May 21, 2005 5:14 am
by el gennaro
Posted: Sat May 21, 2005 5:22 am
by wonder
if i do the project pak....is it easy to upgrade to the ultra pak? or is it the same price as buying it new?
Posted: Sat May 21, 2005 7:25 am
by jackorhythm
try the urs demos.
Posted: Sat May 21, 2005 11:13 am
by bralston
It is much more expensive to upgrade a Project Pak to have the same plugs as the Ultra Pak.
Project pack is $399 at jrrshop.com
Add all the plugs seperately to make it the equivalent of an Ultra Pak will cost you an
additional $1380.
The Ultra Pak is $1199.95 right from the start. And it gives you all the plugs available right now...except the new Roland ones coming out in the next update.
The project Pak is really designed for users to cheaply add additional DSP cards to their system, as you can add up to 4 cards in one computer which will work in tandem on all the plugs you have authorized.
The Ultra Pak is really the way to go when buying into the UAD-1 for the first time.
Posted: Sat May 21, 2005 12:45 pm
by chrispick
Add all the plugs seperately to make it the equivalent of an Ultra Pak will cost you an additional $1380.
Or the Studio Pak for around $900 or so. Doesn't have the Plate or Pultec Pro, but still has the 1176, Fairchild and LA2A (as well as a few other goodies). Might be all you need.
Posted: Sat May 21, 2005 1:26 pm
by donreynolds
I have been happy with the waves native gold and the DP plugs
Posted: Sun May 22, 2005 8:00 am
by Watersound
First of all, I'm using a daul 2Ghz G5 and Powercore kills my processor...that is BS that it takes the load off. Also, be wary, their customer support is bad...I had a painful experience with them and will never give them another penny. Go with Waves!!
Posted: Sun May 22, 2005 9:07 am
by wonder
at this point...its waves vs. uad to get my dollar.
I'm leaning towards UAD for the LA2A and 1176
