Page 5 of 6
Re: LAME for DP 8
Posted: Thu Oct 11, 2012 9:52 pm
by James Steele
REPEAT:
All I can tell you is it's working for me. The location is different however.
Look in this directory:
<Your Hard Drive Name>/Library/Audio/Plug-Ins/MOTU Audio Export/
You should have three files in that directory:
Core Audio Export.bundle
LAME Audio Export.bundle
libmp3lame.dylib
Since mine is working I'm posting an archive of libmp3lame.dylib here that you can unarchive and drop into that directory and it should work.
http://motunation.com/files/libmp3lame.dylib.zip
If you don't have the other files let me know, but the DP8 installer should put them there I think.
Re: LAME for DP 8
Posted: Thu Oct 11, 2012 10:05 pm
by dix
Go back five or six posts. I put a summary up.
Ah. Missed that. Thanks Dan!
Re: LAME for DP 8
Posted: Fri Oct 12, 2012 7:54 am
by bayswater
Thanks, that's great. Seems pretty straightforward, or at least as straightforward as getting LAME working in DP has ever been.
Re: LAME for DP 8
Posted: Fri Oct 12, 2012 8:11 am
by MIDI Life Crisis
...until you go back to DP7...
Re: LAME for DP 8
Posted: Sun Oct 14, 2012 3:52 am
by dixiechicken
DC here!
i386 or x86 usually refers intel 32 bit architecture
wssv3sp2-kb953338-x86-fullfile-en-us = 32 bit intel
x86_x64 or x64 - refers to 64 bit intel architecture
wssv3sp2-kb953338-x64-fullfile-en-us = 64 bit intel
if you see weird stuff like this
amd64 or similar its usuall 64 bit intel - ymmv
Cheers: Dixiechicken!
Re: LAME for DP 8
Posted: Sun Oct 14, 2012 7:42 am
by bayswater
MIDI Life Crisis wrote:...until you go back to DP7...
RIght, that just occurred to me in another thread. Fixing one messes up the other. The process described by dlx could be put in an Applescript for those that need to switch back and forth.
http://www.motunation.com/forum/viewtop ... 15#p436144
Re: LAME for DP 8
Posted: Tue Oct 16, 2012 8:10 pm
by Steve Steele
Thanks James. Just now getting to this...
Re: LAME for DP 8
Posted: Wed Oct 17, 2012 4:25 am
by toodamnhip
It seems to take longer for DP to process a file into MP3 than it does itunes?
Why?
Re: LAME for DP 8
Posted: Wed Oct 17, 2012 7:28 am
by bayswater
toodamnhip wrote:It seems to take longer for DP to process a file into MP3 than it does itunes?
Why?
I have no idea why, other than the obvious, but the same thing applies comparing DP to Logic when it comes to bounces, merges, etc. Logic and iTunes are probably sharing some code here.
Re: LAME for DP 8
Posted: Wed Oct 17, 2012 7:33 am
by MIDI Life Crisis
Doesn't seem slower to me but clearly it needs work as movie options aren't appearing in QT bounces. Then again I'm still adjusting to an 8 core so I may simply be ignorant of the speed difference.
Re: LAME for DP 8
Posted: Wed Oct 17, 2012 1:14 pm
by Shooshie
Why?
iTunes is merely converting.
DP is bouncing all your tracks, effects, and automation in addition to converting to mp3.
Re: LAME for DP 8
Posted: Wed Oct 17, 2012 4:31 pm
by toodamnhip
Shooshie wrote:toodamnhip wrote:It seems to take longer for DP to process a file into MP3 than it does itunes?
Why?
No bro, I don't work like that.
Bouncing in DP?
Bite your tongue, gawd forbid. I NEVER trust DP for such things. I record mixes directly into a stereo track at full, 24 bit resolution. I then listen to a part of the wav file to make sure I routed all parts to the bus and didn't get fooled hearing somthing that was routing to out 1-2 instead of the stereo track. I then go into the audio bin and export as Mp3. It is that process that takes a long time, just exporting wav to mp3.
Re: LAME for DP 8
Posted: Wed Oct 17, 2012 4:38 pm
by MIDI Life Crisis
... and the beat goes on, and on and on and on.
~ Cher
Re: LAME for DP 8
Posted: Wed Oct 17, 2012 7:14 pm
by Shooshie
toodamnhip wrote:Shooshie wrote:toodamnhip wrote:It seems to take longer for DP to process a file into MP3 than it does itunes?
Why?
Bouncing in DP?
To each his own, but I've never had a problem going direct to LAME mp3. I've never had a dropped track, dropped measure, or dropped effect or automation. The result is just like listening to the mix. The stories I hear about those dropouts are very surprising to me.
Shoosh
Re: LAME for DP 8
Posted: Tue Oct 23, 2012 12:27 pm
by dtobocman
Thanks, original poster, for providing an instant solution to an hour long problem!
