My suggestions to the developers to make DP improved
sampolfonz
Re: My suggestions to the developers to make DP improved
Post by sampolfonz »
Shooshie wrote:When you have them selected, maintain your selection by keeping a finger on the Shift Key. Then if you accidentally tap something, you don't lose your selection; you just tap it again to deselect what you accidentally added to your selection.
Mr. Shooshie,
This is what I am trying to describe. If these same events were in a part, they would always be selected and there would be no reason at all for me to have to select them, re-select them or anything....they would always be in a group, exactly where I need them to be, and they would be "grouped" in this part. That is what I want to be able to do with DP. Create some soundbites, on different takes that would be always grouped together. Now, at least the way I understand it, if I use a track with a few takes, bump the takes up to the comp, then they are just all there on the track lane. And, should I decide to move these down the time line (or anything else that is with them in their original take lanes) they don't stay grouped and positioned together. If audio events are in a part (Cubase, Studio One, Logic) they stay that way.
So, instead of having to swipe them with the I beam tool, or manually click them with the A tool, or dragging the A tool to enclose them (EVERY TIME I WANT TO MOVE THEM ALL) they are always grouped together because of the part (container, region). Basically, it is just a box that keeps the data contained until I CHOOSE to move any of the events out of the part. This works great. Is there a way in DP to have these events (on the comp lane and all the events on layers below) stay grouped together, and be moveable? This is all I am after...without having to manually select each time I want them grouped.
Shooshie wrote:Ok, again, select the snares, then go to Search under the Edit Menu. Here is where you will benefit from having a few searches already set up, but it won't take long to set up a new one or repurpose an old one. Use the time grid, set it up for 4/4 bars, and choose ranges of, say, an 8th note starting on all the second and fourth beats. Have this based on the existing selection. It will then select all snares on 2 and 4. Now you can either use the Reshape Tool or the Change Velocity to do what you need done.
If this data was in a shared part (2 measures long, for instance) and then this part was shared copied in the song, all I need to do is open any one of the shared parts and change it one time, and it is logically changed in all the places in the song that this shared part is used. Simple. Simple. Simple. No select, no search, no logical 'if and then, except' formulas. One part, one change, all done.
FMiguelez wrote:
I really don't see what the problem is... You simply make a time range selection and either, move everything manually with the mouse (or keyboard arrows), or use the Shift command for perfect precision.
There are like one million ways to make VERY QUICK and easy time range selections, from dragging on the top of the Editors, to selecting stuff between markers, to assigning beginning and ending of sections with shortcuts, etc.
The problem is having these events all stay locked into relative position with each other. If I record one track, add another take or two to the track, use the comp tool to send various events to the top lane for the comp....and then need to move the entire group down the time line. I have to grab the I beam tool and swipe all of it, or use the A tool to drag around the selection. Then move it. Work on another track for sound effects or music bed, then have to go back to the voice-over track, I have to open all the takes, make sure that I select them all again (God forbid I miss a corner or miss touching one of the events) then have to move it again. If I could drag-select all of these events and then put them in a fixed group (part, region, etc) then all of the events would be selected when I click on any of them. Because, they would be in a group, staying put relative to each other (part, region) they would all be quickly and easily moved as many times as I need to. THIS, my friend is the problem.
:deadhorse:
Dude, I have read the manual. I recorded radio commercials with the program for 5 years or so. While I can always learn more (and I really am grateful to you, Shooshie and others who are helping me learn more....really, THANKS :D ) I know how to use Digital Performer pretty well. I came to DP at version 3 and used it until Cubase released version 5 and they finally got their audio quality improved. Recently, I have been mixing 18 track projects (just basic stuff) in Studio One 2 Professional. But, there are some quirky things in it that I keep reaching for Digital Performer (I have 7.24 and will buy 8 just as soon as I get the notice that it is out, Lord willing) because I like how DP feels, I like the way it looks, I like how it sounds, I like that I can lay on the Waves and Oxford plug ins in my Master channel and I can get the mp3 files out and they sound (somewhat) mastered, without having to go to another step of bouncing and reimporting to do mastering again, just for the simple, basic stuff I'm working on.
Shooshie wrote:
Geez, I learn something new all the time. I did not know that was there. I've been asking for the ability to save selections, and I guess they gave it to me, kind of.
More specifically I'd like the ability to save exactly what is selected. Notes, controllers, etc. But this is a start. Thanks, MOTU!
Mr. Shooshie, this is exactly what I am wanting...to be able to save a selection, whether it be MIDI note events or audio events. I want the ability to put these in a CONTAINER, or group so that I can freely maneuver them all together without having to re-select them every time. That is IT !!
I hope you all do not think my aim is to be difficult here. DP IS GREAT !! With parts and Solo on the channel it would even be better. That's it. And here is the deal: DP already has CLIPPINGS which would be the perfect opportunity to put editable clippings in place. How great it would be to have a CLIPPINGS TRACK. A clipping could be created, and then used, but if it needs to be changed, just go to that clippings track, and change it one time then it would be easy to edit a master that appeared "x" number of times in a song.
Guys, this is what I'm after...a better DP. Love it. I'm getting ready to go out to my shed out back now and work in DP to mix about 4 songs from last weekend and upload to the internet. I love it, I just think I could love it more.
Thanks, guys....
Sam
rickorick
Post by rickorick »
I think F3 and F4 by themselves set the in and out points for Auto Punch. You don't need the Option Key.
rickorick wrote:I think F3 and F4 by themselves set the in and out points for Auto Punch. You don't need the Option Key.
Mine are set that way by me, so that my OSX uses for F1 - F5 will not be disturbed. I should have mentioned that.
sampolfonz wrote: Mr. Shooshie, this is exactly what I am wanting...to be able to save a selection, whether it be MIDI note events or audio events. I want the ability to put these in a CONTAINER, or group so that I can freely maneuver them all together without having to re-select them every time. That is IT !!
Thanks, guys....
Sam
I get that, Sam. I have two reasons for saying what I've said in regard to Regions in DP. First, having not added them for 25 years, it's unlikely that they'll choose to do so now. The guys at MOTU come from a different point of view, where Regions form a "school of thought" about MIDI usage, in which your MIDI is managed for you and put into a container, then you have to pull it out of that container when you want to do anything to those notes individually. The Region, then, is an over-zealous babysitter who insists that all kids be in bed by 8 o'clock, no exceptions. When you want to make an exception you almost need a note from Dad to make it happen.
Logic is an example of that. It took me a long time to figure out how to get notes out of the Region container, and frankly it's more trouble than it's worth. Far easier to collect them together for group actions and therapy than to get a letter from God saying you can remove them. That's just one example of Logic's shortcomings that do not appear until you really want something that Logic has all tied up and battened down.
Anyway, The only form of Regions that I would willingly accept in DP would be one in which you collected a bunch of objects and saved them as a region, yourself. I'd call it "Saved Selections." It would consist of more than a selection range. It would contain every object you selected, beginning and end, plus controllers that go with it. But the key would be "Save it yourself." I do not want things tied up by default until I liberate them.
Give me those saved selections I just described, and I'll be 100% on your side. Not until! No default trapping of my data into Regions or anything else, no matter how much time it might save someone who ONLY works in regions. If you're a die-hard Region man, then I honestly and sincerely suggest using another app. DP isn't the one for that. Given the option, I would never use Regions, except as I described: my own selections, saved for later retrieval.
Shoosh
