How many folks are using DP Mixerless?
Tonio
Re: How many folks are using DP Mixerless?
Post by Tonio »
CS does look intriguing, actually been eyeing it for quite a while. I just wish there was AES and XLR connectors...sigh.
wylie, there is the MOTU 8 pre. Kinda depends on the threshold of breaking the bank....
If you like clean Truth has a 8 channel unit, or Presonus. There should be some more options out there.
T
wylie1
Post by wylie1 »
The 8pre would be good to add 8 channels.
I want to utilize the inputs on the 2408.
This looks interesting http://www.arx.com.au/International/8pre.htm
But I've never heard of them.
Tonio wrote:CS does look intriguing, actually been eyeing it for quite a while. I just wish there was AES and XLR connectors...sigh.
T
Well, you mean AES digital on XLR right? I can't even remember what's on the back of the unit, but I think the analog I/O is on XLR, or at least TRS. Yeah... the fact that it's only S/PDIF is a drag for me too as I don't have S/PDIF. I have a MOTU HD192 and a 24 I/O, so I monitor through the analog outs of the HD192. Still, the converters on the HD192 are supposed to to be as good or better than the ones in the Central Station, so that never bothered me. I would like, however, to have had the accuracy of the metering if using the digital inputs. Presonus includes an explantion on how to calibrate the Central Station's meters to the analog input when you first set it up, but it's not going to be as precise as digital meters. But then probably a moot point as most people are using Inspector XL or something anyway.
I think it sounds really good, and actually Tonio, I noticed early on that the remote unit ran ACTUAL AUDIO through the length of the remote and back again and assumed it would be a problem, but to be honest, I've listened back and forth between the remote plugged in and not plugged in and really couldn't hear any difference. I was worried too because I'm using the remote to literally bring the controls a foot or two closer to me which sounds stupid, but after leaning over and stretching to adjust the volume several times a day, I hooked up the remote anyway.
The remote is worth having. When it was first introduced Presonus ran a special "rebate" where they sent you a free remote when you bought the main unit. Too bad that ran out. Unless you can rack the Central Station in the absolute most ergonomically convenient location, you will want the remote.
SixStringGeek
Post by SixStringGeek »
buzzsmith wrote:(any other users care to comment on Big Knob?)
I have one. I like it. I have 828 mkII, Mackie MCU faders, big knob for monitor switching/volume control. Love it. Makes jumping among references while mixing really easy.
DP 11.newest on MacBook Air M2 24/2T
Korg Kronos Klassic Keyboard 88, Line 6 Helix
buzzsmith
Post by buzzsmith »
James Steele wrote: The remote is worth having. When it was first introduced Presonus ran a special "rebate" where they sent you a free remote when you bought the main unit. Too bad that ran out. Unless you can rack the Central Station in the absolute most ergonomically convenient location, you will want the remote.
I bit the bullet...ordered both the Central Station and the remote from Sweetwater. Got a fair discount for ordering both together.
Should be here Tuesday.
I checked around and, as you said, there ain't no free rebate anywhere, anymore that I could find re: the CSR-1.
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Buzzy
Yeah, that promotion was direct from Presonus when they first launched the unit. Still, I think you'll be quite happy with it!
buzzsmith
Post by buzzsmith »
wylie1 wrote:The next thing I have to figure out once my board is gone is some kind of input device for a 2408mk3.
Is there any analog 8 channel pre amps I can get with out braking the bank?
Maybe the PreSonus Digimax 96K?
http://www.presonus.com/products/Detail ... oductId=12
I've been pleased with it. I didn't realize it was quite this pricey...about 1400.00. I think I got mine on eBay around 600.00.
Currently on eBay they seem to be in the 450.00-1000.00 range.
Buzzy
Focal Twin6 Be(s)
I know this might be obvious, but ask yourself what the most simultaneous inputs you'll ever need. Do you really need 8 channels of preamps? I use my studio mostly for doing overdubs of vocals and guitars, so I spent more money for less channels of higher quality. I went with the Millennia HV-3C on a recommendation of friend and have been happy. It's very uncolored and clean which I felt was safest considering I was going to use this as an all-purpose preamp, figuring I could dirty things up a little bit later ITB if necessary. I wish I had the budget for some different "character" pres, but simply did not.
wylie1
Post by wylie1 »
James Steele wrote:I wish I had the budget
Yes thats my wish exactly
I'm still trying to wrap my bean around this.
I was hoping to find a pre with gain control/phantom power run that into the inputs of the 2048. don't really need another AD/DA for this.
Then I need another pre for drum mikes.I can get MOTU 8pre cheap used but still looking at others.
6 mikes I have on a drum kit.
2 on amps
2 on vocals.
Line inputs very.
I was thinking of putting the 8pre beside the kit and just running fiber to the 2408 apox 25'.
I'd like to have a small Hi end pre for vocals but that has to wait.
I wish I knew electronics I'd strip the pres out of my board.
I figured you were recording drums and other instruments live. Sounds like you need 10 channels of mic pres, huh? Yeah... I totally get that your needs are different. I was lucky to just focus on doing overdubs with my studio so I spent $1700 on TWO channels of mic pre... $850 each channel. If I needed 10 channels I couldn't have even come close to being able to spend that much per channel. Although, I know there are some really good quality options out there nowadays.
Brad?
wylie1
Post by wylie1 »
James Steele wrote:
Brad?
:lol:
Ya I'm still just looking.
I just watched the news I should of drove across the boarder for black Friday.
Tonio
Post by Tonio »
T
James,
Actually, I was refering to AES (digital) and XLR for analogue connections. I do prefer using XLR connectors for my back side (monitoring). I should get over it, but I surmise there is a difference between the cable response i.e. SDIF vs AES & TRS vs. XLR. Funny I would opt for the better cable in my measly home studio 8) Suppose I'm trying to compensate for "better cables" for a lack of quality results :lol: I did research on the digital protocal of SPIF vs AES, and AES appears to be a better bet. Hence, I purchased the Lavry DA-10 for my backsidein lieu of getting the DynAudio BM6a's. I am happy with the results of my purchases and fidelity thereof. Trying to keep in that vein has somewhat biased my decisions on future upgrades of equipment.
Though your testimony of not hearing a difference with the Central Stations remote unit has me baffled. Perhaps I have been reading too much high end gear snobs to the contrary? With all the GAS involved, maybe I should wait for Buzzy's opinion, as I have some other "acquisitions" to consider.
Too much Turkey , and I'm talking out my ass, but It seems SPL 2control is what I'm looking for. Its a biaaatch when you can't demo some of this stuff.
Buzzy, please let us know how it works out for ya!!
T
wylie1
Post by wylie1 »
Tonio wrote:but It seems SPL 2control is what I'm looking for.
T
Yes that's decision I've made as well.
We should gone for a bulk purchase.
Tonio
Post by Tonio »
T
Bulk? didn't hear of one??
That or a Gold Point Attenuator !! http://www.goldpt.com/sa2x.html
Wylie, you avatar get every time !! Outrgeous :lol:
T
wylie1
Post by wylie1 »
Tonio wrote:
T
T
Buzzy already placed his order we may have got a deal on three.
Gold Point is similar to my first switch that crapped out on me.
I see that avatar in the mirror some mornings.
