JamesIII wrote:My wish is that when bouncing a work that contains virtual instruments, DP would just bounce everything without having to "freeze" the instruments first. This is the one thing that Logic Pro 7 does that I wish DP would implement.
Amen, brother!!
As a loyal DP user who has recently started teaching Logic Express to kids, I find this (one of the only things) lacking in DP vs Logic. Also Pro Tools can do a "real time bounce" too - and as far as I'm aware, so can almost every other sequencer!!
As I work with more and more virtual instruments, this missing feature annoys me more and more!! Get it together chaps!!
Please make audio sync actually record in time with mLAN. I have had problems with this since 4.6 and now can't open the projects I am working on now in 4.5 so can't even go back so I can record audio in time!
I am getting latencies of 1000 to 5000 samples that vary every day so can't even set the compensation and leave it at that.. It's driving me crazy!!
Pleeeeeeeeeeeease....
Mac Pro 12 core 3 GHz, Motu Ultralite, DP9.1, Mac OS X 10.10.5 64GB Ram.
salvadorpauli wrote:For example, when I've edited multi-track drums and then quantize, there will be some spaces between many of the soundbites. So, I'll select the soundbites and choose smooth audio edits...edge edit only... and only some of the soundbites will actually have the gaps filled in. It seems improved with the one small test I performed but not completely functioning, yet.
Isn't there a known (adverrtised) limitation that the files to be filled in must have been from the same file and possibly in the same order as original? I don't think it is supposed to fill in two different files as if they were one- that would be Merge, right?
Mac Studio Ultra/ 2013 Trashcan. DP10 and 11.
32 channels of Apogee Symphony MkII/ Dangerous 2Bus+.
Lots of Neve, API, and Dangerous outboard gear.
As a Traveler and Cuemix user, I would love to see the cuemix console faders directly in the mixing window of DP. that way when I save a project , All my cuemix settings for that song would be saved with it.
Rush909 wrote:wish list item: I have consolidated windows setup to display current track mixer channel on the left side of all my windows (SE, Trackst...etc...)... problem happens when I switch to mixer view as my main window (to change mixer settings on a few tracks at the same time) and I go back to SE or Tracks, my consolidated window setup is cancelled... and I have to callup my screen set again with the mixer channel on the left side... would be nice if DP recognizes what I am doing and re-enables my consolidated window with the channel on the left side...
anyone else has mixer channel for current track in a consoldiate windows setup and has the same problem? not a biggie but a wish...
r.
Right this is a weird one, I think it might be a bug.
I've turned off consolidated windows because I couldnt find any way to not have the waveform editor to not appear in consolidated windows.....
ok that worked, but consolidated windows still works. Which is good. I like consolidated windows.
Does anyone else get this? The only reason for it I can think of is that my screensets are save with consolidated windows in them
I second that. For comping this would be really useful. Sometimes a drop in ends up being slightly louder or quiter so just adjusting that soundbite level is very handy.
Optional mouse/fader gear ratio which could be selected in Mixer mini menu!
Default is as it is now... with option of a 2:1 ratio of mouse movement to fader movement. IOW you'll have to move mouse twice as far to move fader same distance as with default setting.
Would love to be able to create patch lists for VIs not listed in Audio/MIDI setup (e.g., sample libraries locked in sample players -- NI products) so I can choose patches (pre-loaded in the sample player) from the Tracks Window.
