***Meeting with Magic Dave and DP6 preview (it's cool!!)***
Excellent review Brad, thanks!
One question: did you have time to check if it is now finally AU 2.0-compliant?
Sounds a bit geeky I know, but it is an important feature for some of us, in that it would allow to effectively use the sidechain feature on AU compressor plugs for example, which is still not doable in DP5. I've been using Logic lately, only because I can route, say a kick to control a comp's sidechain input.
Did you spot the Vintage Suite™ plugs (including guitar amp/cab sim and retro synth VIs), Brad?
Bet they were buried in one of those folders in that newly-configured plug menu...
Are you poo-flinging me or is this a real scoop? (or has the swarming not ended?)monkey man wrote:Did you spot the Vintage Suite™ plugs (including guitar amp/cab sim and retro synth VIs), Brad?
Success is just one more plugin away! And happiness is as close as your next upgrade.
LOL!
Unfortunately bOing, it's wishful thinking on my part, and not much more.
I do believe MOTU's had sufficient time since DP 5 to do a lot of work on plugs and VIs though, and when you consider that DP5 gave us 6 instruments (a ground-tester if ever I saw one), that MOTU has the sample library and technical know-how to create a ripper VI suite, as well as convolution experience which can be used in creating guitar amp/cab sims, all these things amount to an (reasonable, IMHO) expectation that there's a whole lot more to this update than one might expect.
Another possibility is that MOTU's doing its best to set the foundation with DP6 for a swathe of additions, but is willing to put 6.0 out there and service that first to ensure a rock-solid platform for the rest of the enchilada.
Logical speculation, that's all, but the time factor's only serving to heighten my expectation of said revelations.
- Timeline
Exactly what I did with Nuendo's $400 update and I still don't have it. Spiking, erratic multicore and a host of other MAc oriented faults still keep me away. Fortunately the upgrade costs are reasonable enough with DP to just go for it.Frodo wrote:Don't buy it until you feel comfy with user reports-- especially from users whose hardware is similar to yours.Timeline wrote:Hmmm. What happens if we buy the update and don't like it? I doubt that would happen but maybe that's why they are adding all the goodies, just to be sure. Just a crazy thought.
What are you using for the 2nd computer? MMC or Eithernet?David Polich wrote:I wouldn't count on it - especially if you're getting slow results on a new Quad Core - that's tons faster than my dual 2.3ghz PPC G5. Are you running loads of VI's?bradswan wrote:Great to hear about the new features which I'm excited about, but if DP isn't significantly more efficient regarding processing and CPU draw, I know I'll be a bit disappointed. The rending of VI's etc will help, but I'm running into CPU issues already with my new Quad core 2.66, and I'm not really using an over abundance of plugz. My hope is that Motu is taking this time to seriously address this issue and will release a kick ass new DP![/img]
Here's the simple solution to VI's - run them on a second machine, or on something like Muse Receptor. Seriously, I would never try to tax a single machine with the jobs of handling DAW audio and MIDI and running multiple VI's. I don't care how fast the machine is, someone will come out with a VI (or "upgrade" a current one) that gobbles CPU like crazy.
The best decision I made was to dedicate a separate computer to VI's only. I've gotten way more mileage out of my G5 that way. I can run Ivory, two instances of Kontakt, BFD 2.0, Pro 53 and B4II at once, with no CPU load on my Mac, and no latency, thanks to this setup.
To put it all on the same Mac - I just think you're asking for trouble, even though "technically" you "should" be able to do it.
http:www.davidosuna.com
dosuna11 wrote:David Polich wrote:I wouldn't count on it - especially if you're getting slow results on a new Quad Core - that's tons faster than my dual 2.3ghz PPC G5. Are you running loads of VI's?bradswan wrote:Great to hear about the new features which I'm excited about, but if DP isn't significantly more efficient regarding processing and CPU draw, I know I'll be a bit disappointed. The rending of VI's etc will help, but I'm running into CPU issues already with my new Quad core 2.66, and I'm not really using an over abundance of plugz. My hope is that Motu is taking this time to seriously address this issue and will release a kick ass new DP![/img]
Gotta agree, but I'm referring to tracks and plugz
Mac Pro Quad 2.66 5gigs ram, OSX.6.1, DP 7.02 Apogee ADX 16, Mytec DAC, Mackie MCU, MTP-AV, Stylus RMX, Ivory, EWQL, Plug Sound Pro, Mach V, Reason, MX4, Ethno-instrument, Virtual Guitarist2, Do I really need all this stuff? UAD-1,2, Waves L3, PSP, Altiverb, Neodynium, AT 5 various other plugz.
I'm a little late to the party, but not to late to say thanks, Brad. This sort of info is always welcome. Great report.
You're a great guy, no matter what the others say behind your back.
Kidding...just kidding!!!!!
Phil
Phil
However, there's a lot more commercial incentive to sell it off piecemeal so that users of other platforms will find it an attractive buy without changing to another DAW.monkey man wrote:...MOTU has the sample library and technical know-how to create a ripper VI suite, as well as convolution experience which can be used in creating guitar amp/cab sims, all these things amount to an (reasonable, IMHO) expectation that there's a whole lot more to this update than one might expect.
I like DP. Don't get me wrong. But that doesn't mean that there isn't a little MOPOO happening behind the scenes.
Brad thanks for the info... did you happen to use electric keys with DP6???
Was the latency factor still there or have they figured that out. Logic VI's have virtually no latency... I am so hoping DP 6 VIs will work without having to crank the buffers down to 128. My Mac Pro is brand new and compared to my Dual core it is blazing. Still while it is not so bad at the beginning of a project but after I get a big project going and I need to do an odub on something... I have to do a mix, turn everything else off and just use that 2 track mix in playback. It's not the end of the world but it is at least a 5 minute process to get it set up... mix, turn off all channels, change hardware buffer, odub and backagain... ahhh did I leave out the crash...
I'm not complaining DP is my DAW of choice...
waxman
- BradLyons
- Primary DAW OS: Windows
No, but I think I get to play with it in a few weeks.waxman wrote:Brad thanks for the info... did you happen to use electric keys with DP6???
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
Easy, Altiverb uses 32 bit internal engine, the Space Designer plug in in Logic uses 24 bit, and while it sounds good, it's not as good as Altiverb. The new convolution reverb in DP might be 24 bit too....James Steele wrote:Also, I don't understand how one convolution reverb could sound not so good compared to another if they use the same IRs?
Hey if you do, if there is any chance you can play around with MIDI in the Track Overview window and see if the choices for how you view chunks of MIDI have improved? My biggest complaint about DP is the way that the TO arbitrarily breaks up MIDI data without regard to phrases etc. Beyond that I would use DP over Logic. I'm still stoked about DP 6 though, and hope to find someone in Seattle who picks it up to check out the new features etc.BradLyons wrote: No, but I think I get to play with it in a few weeks.
BTW there's a chance however slim that the new way DP handles VI's significantly bridges the gap between DP and Logic CPU wise. Logic has for years pre-rendered VI's, and if DP does it even half as efficiently expect a 10-15% increase in CPU overhead!
Really? That's the first I've heard that. I was under the impression Logic used dynamic buffers, with a low one for record-enabled tracks and a high one for all others. I'm excited about pre-rendering because I think it might actually surpass dynamic buffering in lightening the CPU load, though I would love to have both!Michael Canavan wrote:Logic has for years pre-rendered VI's…
MP 2.93 GHz Quad :: 16 GB RAM :: OS 10.6.2 :: DP 7.11
