corbo-billy
Post by corbo-billy »
Update to version 2024.7 for all GP DSP fx .
- New MIDI CC modulator
- New MIDI Note modulator
- New 2D Double Spiral modulator
- New 2D Chaotic Drop modulator
- Improved Preset system: Edit subcategory and preset from the redesigned popup menu
- Improved Smoothing for Followers, Macros & Motion3D modulators
- Load a built-in preset on startup: If you prefer to load the default preset like before you can change that in Settings Menu->Manage Presets
- Modulators don’t reset on BPM change in AUM (Thanks Gav!)
- MagicDelay: Show current max delay time in CurveEditor
https://gs-dsp.com/
_ No individual installer for this editor _
corbo-billy
Vienna Synchron Player updated from v. 1.3.1674 to 1.3.1748
v 1.3.1748 - October 14th, 2024
alixed
• Occasional Start-Up crash due to corrupted cache file
corbo-billy
U-he Colour Copy and Twangstrom in 1.0.2 version .
- Supports the latest macOS versions (Sonoma/Sequoia)
- Supports CLAP (www.cleveraudio.org)
- Native Apple silicon support for Pro Tools (AAX)
- Key Control (experimental feature )
- Added 50% and 60% GUI scaling options
- VST2 to VST3 migration support for hosts with IPluginCompatibility interface
- Several browser improvements, including more drag & drop features
- Improved parameter automation in Pro Tools
- Several improvements to the Windows installer
Notes:
- There are the final version with VST2 support
- Also the final version with 32-bit support on Windows
- AAX and CLAP versions are 64-bit only
MFM2 2.5.1 version :
changes in version 2.5.1
- Key Control (experimental feature)
- Linux version now supports MTS-ESP microtuning
Notes:
- This is the final version with VST2 support
https://u-he.com/
UVI Falcon updated to 3.1.0
Looks pretty cool. Has audio previews of instruments ala Komplete Kontrol in this version and preset tags. Make sure to install the new product called "Tag Library" that now appears in UVI Portal.. It's pretty big though at 2.83 GB. I'm planning to take a look and see if I can delete tags (I assume at that size it may contain the audio previews also) of instruments I don't have.
3.1.0
- Add new browser with preset tags, audio previews, improved search, favorites, and an optimized
layout
- Add VCF-4023 FX: A virtual analog emulation of the ARP 4023 VCF circuit (as found in ARP
Odyssey rev1) featuring OTA saturation and self-oscillation
- Fix double note issue in Cartesian sequencer
- Fix sustain pedal issue in mono mode
- Fix crash when trying to connect a sub modulation higher than on the Program level
- Add option to rewrite underscores as spaces in Open Sound Control addresses
Re: UVI Falcon updated to 3.1.0
Watch out with the UVI Portal update of Falcon 3.1.0. For some strange reason it simply downloads the installer do the Downloads folder (at least on my system) but doesn't actually run it. UVI Portal reports it's installed, but it's not.
More on the new Falcon 3.1.0:
I had the hardest time figuring out how I was supposed to hear the instrument previews. There's a new manual you should download with this version. I finally had to double-click on the first instrument in the left pane where it says "Empty" and then the new browser appeared and THAT is where you can hear audio previews if there are any. (There's also a little folder icon up near that top of the GUI in the middle that will activate this.) Obviously there wont be previews for older libraries, like the MOTU library.
East West OPUS 1.5.3 updated to 1.5.4
Not sure of what's different. Just launched Installation Center tonight and saw the notification.
Pulsar Audio Updates
https://pulsar.audio/download/
1178 updated from 1.4.5 to 1.5.0
8200 updated from 1.1.5 to 1.2.0
Echorec updated from 1.6.5 to 1.7.0
Massive updated from 1.3.5 to 1.4.0
Mu updated from 1.5.5 to 1.6.0
Primavera updated from 1.1.5 to 1.2.0
Smasher updated from 1.4.5 to 1.5.0
W495 udpated from 1.1.5 to 1.2.0
Poseiden also updated. (I don't have that one).
joelfriedman
Post by joelfriedman »
The Kirk Hunter Farewell Sale: ends Nov. 1st. I know these are older, I guess the questions are whether they're worth it and whether they'll work with OS 15+ and still be usable in a year or 2. https://www.kirkhunterstudios.com/?ct=t ... 872940e11c
Joel Friedman
joelfriedman wrote: Fri Oct 18, 2024 7:26 am The Kirk Hunter Farewell Sale: ends Nov. 1st. I know these are older, I guess the questions are whether they're worth it and whether they'll work with OS 15+ and still be usable in a year or 2. https://www.kirkhunterstudios.com/?ct=t ... 872940e11c
I posted about this in the Deals topic which is a better place to post about these things:
viewtopic.php?p=615089#p615089
I got Kinetic Percussion Motion Engine. The instruments that use Kontakt I imagine would be good for a good long time as they don't use their own playback engine but just need Kontakt.
James Steele wrote: Thu Oct 17, 2024 8:20 pm More on the new Falcon 3.1.0:
Attaching a screenshot in case it helps:
APU Software Updates
There've been a couple revisions since last time I posted for Loudness Meter, Loudness Compressor, Loudness Limiter and Dynamics Optimizer.
https://apu.software/download/
Version 3.0.2
Limiter layout improvement (limiter)
Consistent font for tabs
Version 3.0.1
Performance optimizations
Fix integrated statistics for file load (meter)
ADAM Audio A-Control updated to 1.1
The download is available in your user area after you log in. It also initiated a firmware update on my A77Hs when I first launched it.
https://www.adam-audio.com/en/technolog ... -software/
Release notes
System Requirements
From MacOS 11 to MacOS 15
Windows 10, Windows 11.
A Control 1.1 ships with the latest firmware version “M4”. Besides general stability improvements, A Control 1.1 incorporates the following changes:
ADDED Native support for Apple Silicon processors.
ADDED: Sleep mode to reduce speaker power consumption when idle.
ADDED Behavioural data tracking feature.
IMPROVED Revised saving logic and behaviour.
IMPROVED Enhanced handling of user interface windows.
FIXED Resolved drop-outs during WiFi connection.
Post by Rick Cornish »
James Steele wrote: Thu Oct 17, 2024 7:56 pm Watch out with the UVI Portal update of Falcon 3.1.0. For some strange reason it simply downloads the installer do the Downloads folder (at least on my system) but doesn't actually run it. UVI Portal reports it's installed, but it's not.
I had the same problem. Updated UVI Portal and when I ran the Falcon updater… it downloaded it, but just kept spinning. Had to force quit UVI portal and re-start, then it installed the Falcon 3.1 update just fine.
