I'm not sure what has changed. I suspect maybe NI is tweaking some things in preparation for Kontakt 8 and compatibility with it? It was relatively painless and didn't take too long with a cable internet connection. What's painful is I'm in the midst of a IK Multimedia Sample Tank MAX library update... ugh... like 180+ GB. IK's Product Manager is downloading 100 2-4GB sized disk images one at a time, mounting the image and then updating files in the existing library. I'm only 44% through this thing. I'm going to just have to step away and watch a movie or something. It's been going in the background while I've been catching up on the online audio forums.cuttime wrote: ↑Mon Sep 23, 2024 10:21 pmI'm trying to figure out the difference between the old KFL2 and the new one, and can find very little info. Waiting for your impressions.James Steele wrote: ↑Mon Sep 23, 2024 9:47 pm Update to Kontact Factory Library 2
Just ran Native Access and saw that Kontakt Factory Library 2 has an update. I'm guessing in preparation for Kontakt 8, which I haven't seen. I went ahead and popped for the upgrade from Komplete 14 standard to Komplete 15. Should be interesting.
Re: Update to Kontact Factory Library 2
Ahhh... Kontakt 8 now finally appears in Native Access for me. I'm going to have to do the install tomorrow as I'm busy updating Sample Tank 4 MAX library... and then I'll have do a Time Machine backup which will have to include all of those updated samples before I'm willing to risk installing Kontakt 8. No way I do that these days without an APFS snapshot of my boot volume!
- corbo-billy
I am surprised after this update because finally, Kontakt 7 can open its content despite the Release Notes.
That's a good thing, because I didn't even check the release notes when I updated it. Maybe it wouldn't have let me if I hadn't updated to Komplete 15?corbo-billy wrote: ↑Tue Sep 24, 2024 12:09 am I am surprised after this update because finally, Kontakt 7 can open its content despite the Release Notes.
I am very pleased to say that the dmg files are actually getting smaller now... Some are 1GB or less... what a relief!James Steele wrote: ↑Mon Sep 23, 2024 11:41 pmIK's Product Manager is downloading 100 2-4GB sized disk images one at a time...
- corbo-billy
Yes, so pay attention to the content of the updates and their consequences: I think that this notion of compatibility will one day be effective anyway.James Steele wrote: ↑Tue Sep 24, 2024 12:11 amThat's a good thing, because I didn't even check the release notes when I updated it. Maybe it wouldn't have let me if I hadn't updated to Komplete 15?corbo-billy wrote: ↑Tue Sep 24, 2024 12:09 am I am surprised after this update because finally, Kontakt 7 can open its content despite the Release Notes.
There's a topic started over at VI-Control about this issue with the new library. I guess not all the instruments are compatible with Kontakt 7 because a few posts down in that thread, someone posted a screenshot of an instance of Kontakt 7 showing an error when attempting to load an instrument.corbo-billy wrote: ↑Tue Sep 24, 2024 12:19 amYes, so pay attention to the content of the updates and their consequences: I think that this notion of compatibility will one day be effective anyway.James Steele wrote: ↑Tue Sep 24, 2024 12:11 amThat's a good thing, because I didn't even check the release notes when I updated it. Maybe it wouldn't have let me if I hadn't updated to Komplete 15?corbo-billy wrote: ↑Tue Sep 24, 2024 12:09 am I am surprised after this update because finally, Kontakt 7 can open its content despite the Release Notes.
I am a little worried about migrating things to Kontakt 8, but I just remembered the majority of my projects are using third party libraries or specialized NI libraries and not the Factory Library.
Carbon Copy Cloner updated to 7.0.3
Yes, it's a utility, but I know many of us use it.
Fixed
Fixed an issue in which CCC's helper was occasionally not completely exiting on startup in cases where there were no scheduled tasks. This was leading to cases where the task history database would be closed, thus disallowing new entries to be recorded.
Changed
Improved the experience of editing a password in the email server settings panel.
Fixed
Addressed an edge case scenario where file ownership/permissions were preserved despite using the "Don't preserve permissions" advanced setting in cases where files were cloned via the APFS clonefile() method (i.e. in cases where the source and destination are folders on the same APFS volume).
Changed
CCC will apply a more strict 5GB minimum free space requirement when the destination is the startup disk (or a volume in the same APFS container as the startup disk).
Changed
Adjusted how ASR is invoked when creating a legacy bootable copy of macOS Sequoia on Apple Silicon Macs. This corrects some cases where the destination would fail to boot and the macOS Boot Recovery Assistant would indicate that macOS would need to be reinstalled. This does not resolve all of those issues, though. We have still found ASR to be a little bit inconsistent in its ability to produce bootable devices on the Apple Silicon platform, despite creating perfect byte-for-byte copies.
Changed
Implemented a workaround for some oddly-specific folder corruption on Lucidfs that occasionally prevents CCC from creating the write readiness cookie file, despite having no trouble creating other files in the same folder.
Changed
Task groups no longer get a "success" icon if they run (e.g. on a schedule) but have no tasks to run (e.g. because all tasks within it are disabled, or because the group has no tasks at all).
Fixed
Fixed a false-positive postflight re-verification error that was affecting filesystem-compressed files on macOS Sequoia.
Changed
Resolved a scenario where files that had been duplicated via the APFS clonefile() procedure were getting re-cloned on the destination during each run because macOS adds a GateKeeper extended attribute to files on the destination.
- corbo-billy
It is also discussed here:James Steele wrote: ↑Tue Sep 24, 2024 12:11 amThat's a good thing, because I didn't even check the release notes when I updated it. Maybe it wouldn't have let me if I hadn't updated to Komplete 15?corbo-billy wrote: ↑Tue Sep 24, 2024 12:09 am I am surprised after this update because finally, Kontakt 7 can open its content despite the Release Notes.
https://vi-control.net/community/thread ... st-5606588
You mean the VI-Control thread that I linked to in a post two posts above yours?corbo-billy wrote: ↑Tue Sep 24, 2024 3:55 pmIt is also discussed here:James Steele wrote: ↑Tue Sep 24, 2024 12:11 amThat's a good thing, because I didn't even check the release notes when I updated it. Maybe it wouldn't have let me if I hadn't updated to Komplete 15?corbo-billy wrote: ↑Tue Sep 24, 2024 12:09 am I am surprised after this update because finally, Kontakt 7 can open its content despite the Release Notes.![]()
XLN Addictive Keys 1.6.3 updated to 1.7.0
This is all release notes mentioned:
• Updated license handling
• Updated to latest version of platform
IK Mutlimedia T-RackS 6 updated to 6.0.2
I had the MAX version, but I assume all versions updated. Run IK Multimedia Product Manager to update
• Resolved an issue where loading a T-RackS 6 AAX Plug-in could result in loading the wrong Plug-in
• Resolved the name clashes with plugins from other companies.
• Resolved an issue with Comprexxor presets where the No Dist parameter state would be lost
• Fixed a crash in the assembly window while editing metadata
• Installer on Windows now uses the users choice (if exists) as default for VST3, AAX path
• Module Manager on Windows now uses the plugins path choosen during the installation phase as default
I'm longer seeing this release note. Has something changed?corbo-billy wrote: ↑Tue Sep 24, 2024 12:09 am I am surprised after this update because finally, Kontakt 7 can open its content despite the Release Notes.
- AKontakt.jpg (105.15 KiB) Viewed 1636 times
- Screenshot 2024-09-25 at 3.37.30 PM.png (34.09 KiB) Viewed 1636 times
- corbo-billy
Yes, you are right !
Kontakt 8 updated to 8.0.1
Release Notes
Version 8.0.1 2024-09-26
FIXED
Unable to create new Instrument from loading audio file in Classic View (whilst other Instruments or Tools are in view)
FIXED
Leap: quantising will stop all other notes in group mode
FIXED
Tools: Missing "Off" state for Dynamics mode on the Ul
FIXED
Chords: hanging notes when using this Tool
FIXED
Chords: Recorded chords not being strummed as intended
FIXED
Phrases: Retrigger modes "Off" and "Legato" modes not working correctly
FIXED
Phrases: Missing NKS1 labels for Retrigger and Dynamics mode
KNOWN ISSUES.
KNOWN ISSUE
Leap: While adjusting tuning, all voices playing in single mode will be set to the same pitch
KNOWN ISSUE
Spacebar not reaching DAW when content is loaded from the side pane Browser
KNOWN ISSUE
Crash on loading Pro Tools project with many instances, whilst using Kontrol MK3 keyboards
KNOWN ISSUE
Leap: duplicating Kontakt instances containing Leap presets may trigger a missing content dialog (which can safely be ignored)
KNOWN ISSUE Loading a sample via drag and drop on a rack that is not empty can cause an incorrect error dialog to appear. Please create a new Leap from the menu and drag samples onto it instead
