NEW: SSL Listen Mic Compressor - free plug-in
mikebeckmotu
Post by mikebeckmotu »
Like Jeff said, it's touchy, but I ran it on an aux track with some compression and EQ, and it made a lame little drum loop sound huge. I like it, though it's not for everything.
Brewster
Post by Brewster »
thanks for the heads up guys...
i got a short cut set to me from the site...
if any one else neds it go here
http://www.solid-state-logic.com/store/ ... v1_1_3.dmg
G4 PowerBook 1.67Ghz 2Gb of ram
OSX 10.3.9
Motu Traveller, Motu FastLane MIDI
DP4.12 / Live 4.14
Recycle 2.1 / Peak 4.11
VSTI's & Kooky Plug-in's
NotRude
Post by NotRude »
I downloaded it and yes the site is confusing, the download process is vackasswards, what a pain, now my problem is after installing both VST and AU versions I still don't see them in the Audio>Plugins menu, can someone tell me what I have to do to get this to work? Don't hate me cause I'm more of a ProTools guy, but in PT you install you pulldown menu and voila there you have it, what's up with this? Help will be very very very appreciated
Mario
OOF
Post by OOF »
sdfalk, if it's not a hassle, could you email that plugin also? thanks very much,
david
musegardenrecording@yahoo.com
cleantone
Post by cleantone »
Anyone care to give a quick run down on how to get this into DP? I ran the AU install and it shows up in Peak but not DP. Same thing with the King Dubby plug I tried to install.
Ernest Buckley
Post by Ernest Buckley »
I`ve tried running the plug, no problem. Its pretty cool. The only problem is DP quits on me after I play with the plug for a few minutes to dial in the sound I want.
FREE Plugs are Cool.
FREE Plugs that screw up my G5 are not.
dtobocman
Post by dtobocman »
I'm downloading mine as I type this... thanks for the link!
Ernest Buckley
OK, I have had some time to mix with the plug. Its useful for certain things but very few. However I did discover that it works quite well on vocals. The plug actually boasts the breathes and the mids, completely ridding the low freqs which could be a cool vocal EQ.
The comp sucks on the stereo bus but again, it could be used as a very cool effect so...
The fact that its free is cool.
newrigel
Post by newrigel »
I would like to see some more free stuff out there since I as a composer have to give away some of my material...
It's nice to see something free from a reputable company...
cleantone
Post by cleantone »
anyone?
NotRude
Post by NotRude »
anyone?
this would be the most useful response, I cant get mine to show up either
Mario
belexes
SSL
Post by belexes »
don't go to too much trouble - I thought it was useless
alphajerk
Post by alphajerk »
i cant find much use for the plug either.... good thing its free.
dual gHz, OSX 10.3.9, DP 4.6, PSP plugs [then a load of nice hardware]
