No MOTU MIDI timepiece in MIDI studio...
Re: No MOTU MIDI timepiece in MIDI studio...
Thank you Mike. Much appreciated! Let's see when you see the V-mark as in victory in my next post. Best to you and thanks again. /Boris
V-sign for Victory! Finally I got my two MTP AV working under Sonoma. Was it Sonoma 14.4.1 that did the trick? Or was it that I disconnected every singel cable from my Mac Studio Max (2022) and upgraded to Sonoma from Ventura? Restarted with all cables inserted again... All this are very familiar to me when it comes to MOTU and their lack of interest in updating their drivers. It works now and I'm happy with that. No more MOTU will ever be in my studio again. Sorry to say.
The last driver v91217 for MIDI Express 128 is dated May 17, 2022, This driver works with MTP AV. I've one MTP AV USB and one MTP AV serial with Net cable. All 16 MIDI channels shows up in Clockworks.
//Boris
//Boris
Glad you got it working. Many of us have.OctoUser wrote: ↑Mon Apr 15, 2024 7:46 am V-sign for Victory! Finally I got my two MTP AV working under Sonoma. Was it Sonoma 14.4.1 that did the trick?.
The driver is not the issue. The installer is. Apple keeps changing the goalposts.
The key to installing the MOTU MIDI driver is to remove any conflicting files first—including all MOTU Audio drivers and other MIDI drivers. Once you have MIDI working, the other drivers can be reinstalled.
It would be nice if MOTU would post this in a tech bulletin. There are a few threads here that have this info.
It would also be nice if MOTU would list the current drivers that let the MTP AV USB still work but they’ve made a business decision not to support hardware that was discontinued over 15 years ago. BTW, that MTP needs to have firmware 2.0.1 and USB controller 1.34 chips—the last of those were sold in 2012.
Try getting support from Apple for a 15 year old Mac and let us know how that works out. That is what you are demanding of MOTU.
Hey, you got it working (as have I and others around here). Time to declare victory as we have. Enjoy it!
I did not remove anything this time. I simply updated Ventura from Apples own suggestions. I pushed the update and restarted. And voilá MTP AV came up in Clockworks. MOTU and Apple seems to be “disconnected”. MOTU (I have a few other than my two MTP) don’t give a crap about us with older stuff. Well, I just bought ESI instead of MOTU. Just in case….
I'm not necessarily a fan of depreciation, but a lot of times it can be because Mac OS stops supporting certain hardware configurations. NI had this happen with Kore and other older audio interfaces they made including all Rig Kontrols. Now of course this is partially because NI and MOTU are selling you mostly mid range gear. How many decades is it cost effective to support a maybe at most $350 MIDI interface you no longer sell?OctoUser wrote: ↑Mon Apr 15, 2024 12:23 pm What is “goalposts”? I did not remove anything this time. I simply updated Ventura from Apples own suggestions. I pushed the update and restarted. And voilá MTP AV came up in Clockworks. MOTU and Apple seems to be “disconnected”. MOTU (I have a few other than my two MTP) don’t give a crap about us with older stuff. Well, I just bought ESI instead of MOTU. Just in case….
No more MOTU in my studio, that is a fact.
RME for instance still support the Fireface 800, drivers are constantly being updated, I recently bought a power supply board from them and replaced it myself. The thing is the FF800 was a little under $3000 when it came out. All that said I bought a used Emagic Unitor 8 because apparently Apple is still rolling out drivers for it, but that's the always top five richest company in the world. I also only bought the Komplete Kontrol 88 mkII when I determined that it could be used as a controller without a MIDI driver, because NI don't have a good reputation for longevity of drivers.
ESI, we will see, will they last? who knows?
That didn't work for those of us who had MOTU Audio or certain other 3rd party drivers installed. Worked fine over Ventura and updating to Sonoma did not work. We figured it out.
Hello, everyone -
Thank you for all the ideas and experience in this (and other related) threads.
In case it helps (or gives hope) to anyone attempting to get their aging MOTU MIDI interface working with a recent Mac OS:
I was able to get my MIDI Timepiece AV working in the latest MacOS Sequoia (15.3.1) on my MacBook Pro M1 Max.
These steps did the trick:
1. Delete all the following (as noted in this thread):
/Applications/ClockWorks.app
/Applications/MOTU USB MIDI System Extension.app
/Library/Audio/MIDI Drivers/MOTU USB MIDI Driver.plugin
/Library/Audio/MIDI Drivers/MOTU MIDI Driver.plugin
/Library/LaunchDaemons/com.motu.driver.usbmidi.dextproxy.launchd.plist
/Library/Application Support/MOTU/MIDI (folder)
/Library/Extensions/MOTU\ MIDI\ Driver.kext
2. Restart
3. Install from the latest installers (which must be the latest installers listed on MOTU's download area of their site under a different interface, like the MIDI Express 128 (2022), since those under the MIDI Timepiece AV are out of date, from 2017).
4. Re-start again. Mac System Report shows the presence of the interface, but AudioMIDI Setup does not see it, so neither do my DAWs.
5. Follow the instructions here for Sequoia.
Enabling MOTU drivers in macOS 10.13 High Sierra or later
https://motu.com/techsupport/technotes/ ... igh-sierra
The Extension window looked a bit different from that on the MOTU support page, and only included one MOTU item, MOTU USB MIDI System Extension.app (com.motu.driver.USBMidiDext)
- toggle OFF
- restart again
- toggle back ON
After all this, AudioMIDI Setup and Logic see and can use the interface!
Best regards
2. Restart
- toggle OFF
- restart again
- toggle back ON
Best regards
