Re: When will DP offer articulation sets?
Posted: Sun Mar 14, 2021 9:06 am
Some people actually do use DP as he described for live shows, it’s particularly useful for live theater shows, for example.
Regarding articulation management did you even read what I wrote. Logicpro, cubase and cakewalk CAN do the things mentioned which S1 does not.
But you are right that as of now, there is no single king of articulation management that can do it all.
I have been following articulation management issues I particular very very closely for the past few years, I’m even working on a plugin solution that may or may not see the light of day past my own studio. I have followed closely what various third party solutions can and can not do, what each daw can and cannot do; and what the user base out there keeps running into in terms of challenges with sample library Instruments and the desire to build large and convenient orchestra templates.
None of the daws seem to pick up all the things needed, they have all fallen short in a few areas that had left composers frustrated and often times just ignoring articulation management and either embedding key switches in their tracks or putting each articulation on its own track the old school way. The various articulation management features that have been provided are usually good enough for some simple scenarios but become inadequate once you get deeper into it.
I can say confidentially that the ultimate articulation management system would include the following features to cover 99% of use cases:
- unlimited number of key switches per articulation, including cc and pc switches in addition to notes
- able to channelize notes per articulation. This requires also that supporting cc, pitchbend and aftertouch events also be channelized to the same channels where the notes are going.
- latency correction to make up for widely varying sample attack transients with a single instrument. Today composers have to painstakingly nudge each note ahead of the beat by varying amounts per articulation. This is a huge area being missed by daw systems today.
- ability to attach articulation specifiers directly to notes or being able to assign specifiers that apply to a general range of time for any notes within that time. Cubase refers to these approaches as attribute or direction. Both situations are needed and useful.
- ability to have articulation groups. Cubase is again a good example. That way you will not need a humongous list of every possible key switch combination provided by the instrument.
- input switching mechanisms in order to play parts in quickly while changing articulations on the fly. Needs to be able to integrate with third party touchpad systems such as lemur and others, which means using MIDI, osc and other tech
- visual representation on the piano roll and other places to see the articulation specifiers visually over time in relation to the notes.
