Duplicate files on import
Re: Duplicate files on import
Well, I've no idea why it doesn't do that on my system. Could it be a driver issue? I updated a driver recently, but now I don't remember whether it was the audio or MIDI. I've tried all the things you guys have said, and it just isn't happening here.
That's by no means the first time that my system behaves differently than others'. I've got a long-standing bug that I have yet to figure out. (not to change the subject, but merely to illustrate the bizarre nature of "individualized" systems) My Branching UNDO does not work. I'm not sure it ever did. I can open any project on my hard drive, and even though I've always had the Branching Undo turned on (at least since it became an option, way back there), there are still no branches. This has been going on for at least a decade, over many versions of DP, many drivers, and many computers.
Don't bother telling me all the things to try unless you've seen this before and you KNOW the answer; I've tried them all. I've posted about it here several times, gone through everyone's advice each time, and still... no branches. I figured it was a DP bug, but was surprised to learn that it works for everyone else. So... I'm well aware that things can be different on our different systems.
Still, it's frustrating to try to reproduce a bug, but cannot. I mean, I'm happy that I don't have to deal with it... yet... but I wish I could help figure it out. Maybe by comparing drivers or something we might figure it out, yet.
Shoosh
Radiogal
Post by Radiogal »
I´m experiencing the same issue. I get 2 files on IMPORTING a single file into the Soundbite window. File format BWAV. Must be a DP bug. :smash:
I can live with it though.. until it starts itching.. ;)
MAC PRO 6 Core 3.33 GHz, 16 GB RAM, OSX 10.8.5, DP 9 MAC and WIN (64bit/Jbridge) AMPGUI Mellow, Logic 10, Wavelab 8 MOTU 24I/O (x2), MOTU 2408 MK3 (2x), WAVES Mercury 9, SSL, UAD2Quad, McDSP, Sound Toys, Sonnox, Sonalksis, NomadFactory, T-Racks, P&M, LexPCM, AbbeyRoad, DSM, VCC, VTM, FGX, Melda, EWQL SymphOrch/Piano Gold. Mixingdesk: AMEK Big 44, TK BC-1MK2, SSLcomp clones, GAPPre73, PCM91, TC, FMR. Monitors: Genelec 1031, ADAM A7, >40 mics http://www.ragdollproduction.com
Radiogal wrote:I´m experiencing the same issue. I get 2 files on IMPORTING a single file into the Soundbite window. File format BWAV. Must be a DP bug. :smash:
Two files? Or two identical regions in a single audio file with different soundbite names?
Radiogal
Post by Radiogal »
Two files, one with the suffix. "2"
DanielCoe
Post by DanielCoe »
Radiogal wrote:Two files, one with the suffix. "2"
I'll put money on this actually being two soundbites (i.e. regions) that both point to the same audio file.
Mac Pro (Mid 2010) 2 x 2.93 GHz 6-Core Intel Xeon
128GB RAM
MOTU 2408 mk3
Mac OS 10.14.6
I agree. Easy to tell by setting the Soundbite window to list items by Filename, rather than Name (which shows the names of Soundbites, not files)
Radiogal
Post by Radiogal »
FWIW. Mine is normally showing "Time Created". The first file shows first. The second one is with the suffiX "2".
DanielCoe
Post by DanielCoe »
Radiogal wrote:FWIW. Mine is normally showing "Time Created". The first file shows first. The second one is with the suffiX "2".
I usually view my SB window by Time Created and it looks just as you describe.
128GB RAM
MOTU 2408 mk3
Mac OS 10.14.6
Understood, but what the Soundbite window is showing you is soundbites, not audio files.
Radiogal
Post by Radiogal »
Yup and as I'm only importing one audio file, I expect to see only one soundbite, as I haven't even imported it to any track yet.
So IMO it's a big ugly bug. :smash:
Or this must be a new "feature " in DP. :shock: as I never had this issue before.
Phil O
Post by Phil O »
Shooshie wrote:Well, I've no idea why it doesn't do that on my system.
Shoosh, are you trying this with BWAV files? BWAV is the only format where I can duplicate this bug. Also, I use BWAV as the default in DP. I wonder it that's an issue.
Phil
Phil
That's a good question, Phil. I'm not 100% sure of the answer for some of those files. You see, I use Broadcast Wave as my default, too, but I didn't always. For the past... maybe 4 years, Broadcast Wave has been the default. Before that it may have alternated between AIFF and WAVE.
Here's the confusing part. In the Finder and the Soundbites Window, it does not seem to differentiate between .WAV and .BWF formats. Sure, the default is Broadcast Wave, but I see people speaking of .bwav, WAVE .wav, and .bwf when talking about Broadcast Wave. The official suffix of Broadcast Wave files is .bwf, but in the Finder I only see .wav, and in the Soundbites Window, I see only WAVE for anything I have created with the default of Broadcast Wave.
It seems rather that a Broadcast Wave file would end in .bwf instead of .wav. Have I missed something? Are the two formats now one and the same?
In any case, I've used both WAVE and BWAV files (I think) in attempting to reproduce this bug. I have not yet been able to reproduce it. My uncertainty hangs on the fact that I can't positively identify them in DP or the Finder, yet Broadcast Wave is the only WAVE type available in DP now. Short of some other way to tell, I can't say absolutely for certain what kind of files these are, and since the project I was using is old, it may have more than one type in it.
Have I thoroughly confused everyone?
Now, having said that, the original test that I did was in an old project that I use as my "test project" on most examples I post in this forum. I think its origins date back to around July, 2005. At that time, I'm not even sure DP was doing .wav files yet, but there are no SDII files in the soundbites window. Of course, at various times it has converted all my audio to the current preference, because DP has changed its defaults and filetype options. If there were any SDII files in there, they'd be gone now. The same probably applies to original .wav files (non .bwf), but I don't know that for a fact.
So, rather than worry about what kind of wav file I was using, I took another existing project — a current one — and did the same tests with it. These audio files are all from the past month, and were created under the Broadcast Wave default filetype. STILL, no duplicate files. Ever. Anywhere. No matter what method I used (Dragging to various windows, importing audio with Command-F1), I always got one file.
Ok, I'm probably not adding any useful information to this discussion at this point, being one of the people to whom this never happens for some odd reason.
Maybe it's time to check driver versions.
Driver location: /Library/Extensions
  • Firewire Audio: MOTUFireWireAudio.kext 1.6 64254
    —Modified: Friday, October 17, 2014 at 10:01 AM
    PCI Audio: MOTUPCIAudio 1.6 64254
    MIDI: Motu MIDI Driver.kext 1.6 64820
    —Modified: Wednesday, January 7, 2015 at 1:43 PM
On these projects, I've used the MOTU 896mk3 and the MOTU 1296 audio interfaces.
Question: For those who are seeing this happen, could it be multiple regions in a soundbite, each recorded at a different tempo, which caused this? Do you have multiple tempos in the conductor track? Is DP recording multiple regions within a take due to each of those tempos?
Just a question. Probably leads nowhere.
Shooshie wrote:Question: For those who are seeing this happen, could it be multiple regions in a soundbite, each recorded at a different tempo, which caused this? Do you have multiple tempos in the conductor track? Is DP recording multiple regions within a take due to each of those tempos?
No. I tried this by created an empty Soundbite within DP, exporting it and importing it. I'm getting two regions in the import usually, but not always. I haven't figured out the conditions when I get the dups.
