Optimizing DP for fast response
- fsheinfeld
Re: Optimizing DP for fast response
I believe is related to DSP. The more the CPU is pushed the longer it takes to audition. Then again, it might be a combination of things. You can see my setup below which is nothing out of the ordinary, although I do have a large template.
That's EXACTLY right from my understanding as well!Shooshie wrote:Actually, I think the object there is to set the number of drivers that will be used. Thus, there is a driver for the PCI-424, another driver for 896mk3 Firewire, and yet another driver for USB devices.
Each device that adds its own driver should be counted. Multiple devices using the same driver are counted as 1.
At least... that's the way I remember it. Someone please correct me if that's wrong.
