That would make an excellent thread. I feel like starting a "post your Activity Monitor screenshot" thread.nightwatch wrote:What's the largest amount of Real Mem that anyone has seen DP8 use so far?
DP8 and VE Pro 5, the future is here?
Re: DP8 and VE Pro 5, the future is here?
- toodamnhip
But if you ran all these VIs in DP, it’s processor load would kill the computer. In Vienna, the VIs use ram and not processor too much, In DP, these use RAM and kill the processor, I have no idea why.nightwatch wrote:Now that's what I'm talking about! I haven't had time to keep up with all of the boards. But have you run without VE? DP and Kontakt can have all the RAM they want, just keep loading and don't crash on me.toodamnhip wrote:PS, not only is DP power consumption barely above 10%, I am running a bunch of angry VIs that are using 18 gig of ram.
Dont use DP for VIs
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Does VE Pro 5 help at all for low VI counts? It must add its own overhead to the load on the processor, so for low counts on a single CPU, it is worth the effort?
(I can see how it helps for multiple CPUs. I sometimes run plugins on a second Mac via ADAT, and dealing manually with latency compensation is a pain.)
- toodamnhip
Yes, use VE, never put VIs in DP unless you're just goofing off and want to quickly goof around and throw the file away. Seriously, I see no overhead added as compared to straining DP by putting any VI inside of it.bayswater wrote:Does VE Pro 5 help at all for low VI counts? It must add its own overhead to the load on the processor, so for low counts on a single CPU, it is worth the effort?
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
TDH,
Within how many instances across how many machines of VEPro are you hosting all those VIs? And what's your MIDI track situation look like?
I'm beginning to think my track count is the source of my frustrations.
MacPro Nehalem 8core (2x3.33ghz, 64gb RAM, 10.11, Radeon 5770, NVIDIA GT120), DP 9.12
- toodamnhip
One or two instances (64 and 32 bit), one machine, tons of MIDI tracks. I haven't found MIDI tracks to be an issue.sndmarks wrote:TDH,
I did have a strange issue last night of Superior Drummer losing it's ability to be in sync with DP when in VE. I have to find out what happened, did nt have time last night so I just pulled the MIDI into DP which eliminated the problem.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Hmmm. Not what I was hoping to hear. How many MIDI tracks are you talking about when you say "tons of MIDI tracks?" 30? 300? And you're using Event Inputs to send them MIDI, right?
- toodamnhip
30-50 maybe, using one or two extra event inputs.sndmarks wrote:Hmmm. Not what I was hoping to hear. How many MIDI tracks are you talking about when you say "tons of MIDI tracks?" 30? 300? And you're using Event Inputs to send them MIDI, right?
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
