http://web.me.com/Shoosh/Music/Shooshie ... LFlute.mp3" onclick="window.open(this.href);return false;
I probably should have used the legato articulation throughout, in retrospect, but was trying to deal with an annoying problem whereby it simply would not sustain some notes long enough, so I switched to the sustain patch. That caused the lightly tongued articulations. If I could get the legato patches to sustain for the full length of those notes, I would have stayed with it. So consider that a possible limitation of that library which required some creative reconfiguring after playing in the part. The VSL by all means took the longest to create.
Next, Miroslav Philharmonik with IK Multimedia's Sampletank engine, which considerably expands the usefulness of those ancient samples. The result actually surprised me as remarkably expressive and fluid. So, it is evident that the samples themselves are secondary when it comes to expression; what counts is how the interface controls them. I was able to make this usable by speeding up the vibrato (using two Sampletank interface controls: Stretch, and Tempo) and by adding built-in reverb.
http://web.me.com/Shoosh/Music/Shooshie ... vFlute.mp3" onclick="window.open(this.href);return false;
I could probably make even better sounding recordings, but I limited myself to working with what is within each sample library. The exception was reverb for VSL. There is probably a way to get a reverberant space within VSL, but I do not know it, and I didn't want to take the time to learn it, so I just added a touch of reverb externally from Altiverb. In all other cases, there are no external modifications to the sounds.
I had hoped to post the WIVI version, but I must have messed up a setting or something before I bounced it to disk. There was a problem with its vibrato that I need to fix, and that will have to be tomorrow. I really haven't had the time to focus on these things. The irony is that the WIVI was the easiest of all. I just played it. Bam… there it was. That was the extent of it. No reconfigurations, no key-switching to different articulations, nothing. What I played was what you heard. Flute is probably the weakest sound in WIVI, but it was mostly believable and the expression was nice. I'll get it posted as soon as I have a chance to find out what I did to it and how to get it back the way it was originally. Or I may just play it again, Sam. Sorry about that. I was playing around with other instruments in that interface, such as the horn you hear in all the excerpts, and apparently changed some settings on the flute accidentally.
Now, for reference, here is the one done in Spitfire by Andy Blaney (the revision):
- Audio file removed at the request of the owner.
I hope this has been entertaining and enlightening, and that the earlier negativity of the exchange will be mitigated by the attempt to reach out and help make better known the needs of instrumentalists everywhere, while providing sample library developers a chance to see just how to go about that. We all just want progress.
