Nope. I only mentioned RAW because the libraries have the same content and the RAW libraries have the audio demos. You could have got the RAW (REX/Apple/Waves) version of these loops in the no-brainer deal last month (also at $5 a pack), and imported the REX loops into Stylus RMX.James Steele wrote:I'm not much of an expert on looping, but they mentioned these were R.A.W.? Does this mean I can use them in Stylus RMX??? That would be cool!
In this case, these loops load into SampleTank only, but do so in slices so that you can play them much like you would in Stylus RMX.
When you load presets, the full loop will play on the B2 key (I think it's B2 or maybe B1), and then the slices are available all the way up the keyboard from there. That is an advantage that Stylus RMX doesn't have... you can play the full loop along with the individual slices from the same MIDI channel.James Steele wrote:I just picked "World Grooves" in hopes I can do that. I suppose there's looping functionality in Sample Tank... I've never used it before. I'm more comfortable with Stylus RMX... or UVI Workstation.
