Amplidood's GUI mod 3.5.2 (always updating first post)
amplidood
Re: Amplidood's GUI mod 1.6.2 (always updating first post)
Post by amplidood »
1.6.2 released...
bOing
Re: Amplidood's GUI mod 1.6.1 (always updating first post)
Post by bOing »
amplidood wrote:The resting state of the inserts is grey...
Sorry, lots going on in my brain today. Accuracy may not be one of them.
I meant the active inserts - that Lima Beany color. If you dumped the greenishness of it. In RGB, if that green was pulled back you'd have more of a bluish color - which would work with the buttons below ie. solo, etc.
Again, it's only my opinion. And I agree with you and James that a neutral (but visible) separation makes the interface look calmer. The inserts should be soothing too.
I don't like Lima beans personally. Maybe this is the problem. :)
Success is just one more plugin away! And happiness is as close as your next upgrade.
Dwetmaster
Post by Dwetmaster »
And sorry if it has been discussed before but it would be nice to have that same insert/send separator between tracks to continue between the solo/rec/mute/input buttons and the pan knobs.
bOing
Post by bOing »
Great work, Dood. By the time MOTU catches on to this, your design will be better than theirs.
dewdman42
Post by dewdman42 »
amplidood, you're the man for figuring this out. DP6 just came back up on my radar as a possibility.
sdfalk
Post by sdfalk »
dewdman42 wrote:amplidood, you're the man for figuring this out. DP6 just came back up on my radar as a possibility.
Seriously???
It never Left my radar because of a few interface adjustments.
A Metric Halo ULN8-3D…mmmmmmm
amplidood
Re: Amplidood's GUI mod 1.7 (always updating first post)
Post by amplidood »
1.7 released...
hrw
Post by hrw »
Looks great! i'd much prefer this to the white blizzard of DP6. Nice one!
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
HobbyCore
Post by HobbyCore »
Despite being the staunch supporter of the dp6 UI, I have to say that this is looking really great.
I would be very happy if Motu adapted this as an optional theme.
We should start a write-in to see if they would do that 8)
homebilly
Post by homebilly »
dood
thank you for the light pink/rose colored track record triangles. i can now see them. before the grey on grey was hard to see now it is MUCH better!
i update and use your mod all day long every day and am very happy with the progress that you are making :D
ron
http://www.ronmeza.com
Keystation 49e controller
amplidood
Post by amplidood »
1.7.1 released... will check 6.01 compatibilty later...
bOing
Post by bOing »
The background in the mixer is absorbing the mixer ie. there's no contrast but for that white vertical line. Maybe lighten it up slightly. Or even throw in a color. That's just my opinion.
Dwetmaster
amplidood wrote:will check 6.01 compatibilty later...
I've tried 1.7.1 over DP6.01 and only the Mixer Volume fader seems to be reacting weird to the Mod. There is a fader icon stuck at the top of of the fader when you move it down.
amplidood
Post by amplidood »
Yeah, seems they've changed the graphic for the faders a bit. I'll deal with that later today.
bOing
Post by bOing »
I want my money back!!! ;)
