Share your favorite DP tip!
blue
Re: Share your favorite DP tip!
Post by blue »
Originally posted by Schweats:
I was wondering if there is a way to create and save a separate
mixer window for say drums only or strings only and to be able to toggle to it with a single key instead of having to pull down
from the mix board window's mini menu and selecting alternate board layout ? Any ideas ? Many TIA ••¦Schweats
An easier way to get to it is to press the option key while clicking the sequence name in the upper right corner of the mix window. You get a pull down from there instead of from the mini-menu. Don't think there are any key commands as this is a flexible menu.
MP 2.93 GHz Quad :: 16 GB RAM :: OS 10.6.2 :: DP 7.11
Tim
Post by Tim »
Originally posted by James Murphy:
does anyone else hate the consolidated window? my tip: turn that annoyance off in Prefs.
I've not yet embraced it either.
Keith Henry
Post by Keith Henry »
Arrrggghhh!!!!:
OK, does this drive any of you FREAKIN' nuts?
I don't know if this happens to all of you?
If I'm in the tracks window and I double click on an audio region I expect the edit window to open exactly on the file I've selected-but no it doesn't. I'm directed to the top (control track) of the (sequence) edit window, sometimes not even in the same measure I've double clicked. I'll have to zoom out then go find the highlighted soundbite. Same thing is true for going to edit MIDI reigions following the above emntioned technique.
Here's another pisser (from the Consolodated window)-If I select/highlight a MIDI region I want to edit in the Tracks Window and from the consolodated window hit the MIDI tab; I would assume and expect I'm about to be directed to the area I've just highlighted. But no... I'm always taken to the top most MIDI track in the list. I have to then choose (again) from the MIDI track list at the left of the MIDI window the MIDI track I originally wanted to edit, unchoose the MIDI track I was taken to, and (again) go find the MIDI region I had originally highlighted, zoom in with the magnifying glass, etc. Now, let's say I leave the the MIDI window, go back to tracks window, find another region on the exact same track-I go back to the MIDI window, I would expect the same track to still be selected and zoomed in just the way I left it. But NO!!! I have to go through the whole routine again & again, re-zoom blah, blah.....
MAN this pisses me. I waste more time going through this crap.
I hope all that made sense?
If any of ya's have been fighting these same issues and know of any preference or settings (I've looked) that can take me to where I think I should be going....
PLEASE SHARE
Still a great forum-I'm just blowing steam.
Cheers
<small>[ July 06, 2005, 02:50 AM: Message edited by: julio ugliass ]</small>
*Dual 1.25 G4 2GB RAM/OS 10.5.8/DP 4.6.1/UAD-1/Powercore/Virus PoCo/NI/ EWQL/MX4/Symphonic Instrument/Novation V-Station,Nova/Green Oak-Crystal, Orbit, Dark Star
*Dual 2.0 G5 PowerPC 6GB RAM/OS 10.5.8/PT 8/DP 6/UAD-1/Powercore
*Core Duo 1.83 Macbook Pro/OS 10.5.8/PT 8/DP 6 and um....
*5) ultra bad Strats/Egnater Tourmaster 4100/Carvin Legacy/Laney 100W AOR/4x12 Celestions
*Neumann/AKG/Shure
http://home.comcast.net/~keith_henry/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
iMAS
Post by iMAS »
Originally posted by julio ugliass:
Arrrggghhh!!!!:
Cheers
OMG...I thought I was the only one that was annoyed of this problem...I posted this once with no replies. Well, I emailed MOTU and they said that it was fixed in 4.52...but I'm still in 4.5. But if you're in 4.52 and still have this problem...then :mad:
As for the consolidated window thing...I haven't tried that yet so I can't comment on that.
Sylver
Post by Sylver »
I think it can come in handy, depending on what you are doing. It's easy enough to set up a few window sets the way you like. I bet you could even assign hot keys to your window sets.
Oh, Listened to 2 of your mixes last night, BTW. MY GOD, how did you get it sounding so LOUDDDDD? That was insane. Really nice job on that heavy stuff.
Splinter
Post by Splinter »
I have mixed feelings about it and use it but in combination with other "free" windows. I keep the Sequence editor and Mixer window separate and leave the Tracks window in the CW. In the sidebar I keep the Performance window, Markers, Soundbites window and Undo History. When I need it, I open the Conductor track and the Audio Monitor in the left sidebar. Bottomline... my main windows, which are usually larger than the others, I keep separate and leave a visible corner at all times so I can access them with a click.
MacBook Pro Quad 2.4GHz i7 • 10.12 • 16G RAM • DP 9 • MOTU 896HD Hybrid, Apogee Duet, & MOTU Micro Lite MIDI interface • Waves Platinum, Studio Classics Collection, Abbey Road, etc... • Fabfilter Pro-Q2 • Soundtoys FX • IK Amplitube 3, Ampeg, and TRacks 3 • Altiverb 7 • Slate Digital Everything Bundle • Stylus RMX • Komplete 10 • SampleTank 3 • Arturia V Collection • M-Audio Axiom 49
No, actually I'm one of the ones who trashed the very idea of a Consolidated Window, and said I'm set in my ways and would never use it. Guess what I use 90% of the time! You guessed it. The Consolidated Window. I have about a dozen configurations of it saved, which pop up at a keystroke. (I use QuicKeys, which gives me more options for keystrokes even than DP)
Plus, I still have some configurations that do not use it. Just because it's turned on doesn't mean you have to use it all the time.
What I like most about it is that I can go from chunk-to-chunk easily, just by turning on a new chunk, and will already have the exact same layout in front of me for that chunk. That was impossible before. I switch between consolidated and free windows easily using Apple's Exposé, which I have configured for the left side of the keyboard, so that I don't have to move my hand from the mouse. Exposé rocks! So do Consolidated Windows and QuicKeys.
And there are some of my favorite tips imbedded in the above few paragraphs, for those whose ears are open.
<small>[ July 06, 2005, 08:11 AM: Message edited by: Shooshie ]</small>
Or use QuicKeys. You can do almost anything in QuicKeys with a mere keystroke. It's the most powerful tool in the DP aresenal. Too bad you have to buy it separately, but it's worth it.
TOD
Post by TOD »
Highlight a bunch of track names in the track window, hit option + A and you can simultaneously chnage the inputs and outputs of multiple tracks all at once.
DP 5.13 dual G5 2.7 synced to dual 1.42 via SMPTE, Muse Receptor (filled with Stylus RMX, Trilogy, Atmosphere, Elektrik piano, Disco DSP), OSX.410, Ableton LIVE, Apogee Big Ben, Apogee mini DAC, MachV, Symphonic, Ethno, M-Tron, Mx-4,Latigo, Jupiter Vi, iDrum, Microtonic, Kontakt3, Bassline, Bassline Pro, Ultra Focus, Novation Basstation, Novation Drum Station, Nord Lead2, JD-990, EMU Proteus, Orbit 2, MicroKorg, UAD, Poco, Altiverb, VW2, Waves, Ozone, to name a few :)
Keith Henry
Arrrggghhh!!!!:
[qb]OK, does this drive any of you FREAKIN' nuts?
Yeah, all this is me using 4.52
*Neumann/AKG/Shure
Timeline
Post by Timeline »
When you double click on a track to open waveforms, DP should open the waveforms window revealing the same track in the middle of the others around it so we don't have to rescroll. This should be the way it works.
There are many issues like this that, for some reason, MOTU doesn't seem to feel it's important to address or maybe can't figure out a way to do it without mega C++ +++code additions.
<small>[ July 06, 2005, 09:31 AM: Message edited by: Timeline ]</small>
amplidood
Post by amplidood »
I'll repost my tip here to help with that. In the Commands Window, go to the Navigation section. The very last command in that group is my secret DP weapon that noone ever seems to know about or use..."View Selection in Sequence Editor". Reassign the keystroke of that command to something that a human being could actually do on a regular basis. I personally use "S" for it, since I've never used the "Scrub" tool even once in my life. Now highligt a track or section of tracks in the Tracks Overview, and hit your new magic key. HAPPINESS!!!!
Tonio
Post by Tonio »
mmmm, kibbles and bits, kibbles & bits :D
Are you kidding me? I've even asked MOTU for a way to do that. How long has it been there? Wow! Thanks for that. (I'll have to try it out later.)
PS: is anyone making a consolidated list of these, with boldfaced headings for each tip, organized by category? (hint, hint...) I guess if nobody else does it, I'll get around to it some day. This would make an excellent FAQ for a permanent location somewhere.
<small>[ July 06, 2005, 11:25 AM: Message edited by: Shooshie ]</small>
wonder
Post by wonder »
yeah, that "OPTION A" tip has saved me SOMUCH TIME!
