Kubi wrote:daveyboy wrote:Same guy Kubi (Stephen in LA)?
Same guy indeed...
Thanks Davey for a word of sanity here, and a brief reminder for everyone how to check a suspicion, and to *maybe* do so
before making grandiose claims all over the net...? Isn't there a CD by 3D audio comparing a mix using the same raw audio tracks at the same levels and pan settings, using different DAWs and no plugs? Now that's a more meaningful way of checking things in a controlled experiment.
whatever...
Yes there is. I have it, and I took the test. They compared 31 different systems; all Mac and PC DAWs, various digital boards, as well as SSL, Neve analog, and the Manley and Dangerous summing boxes. They were all pretty close. No one was told which was which for quite a while. Then the shockers came. First off, the analog mixes were LAST on everybody's list. No surprise to me, btw. Go to the forum, search for DAW SUM, and you'll find it.
There was another thread on the DUC, where a highly technical guy proved that the bus only takes a hit when levels exceed -12dB on the various channels. I don't remember the details, but it involved using a tone generator, and visually observing distortion on an aux as you increased levels on the channels. It was very convincing, and confirmed my fear that "packing the meter" was a bad technique.
Being an old analog guy (I'm 53, life-long career engineer) this all makes sense to me. Tracks that are recorded hot may sound fine if you rout them to direct outs, but absolutely slam the mix bus if they go to a master fader. Especially if there are 30 or 40 of them.
It's long been felt that very simple mixes (few tracks) sound fine in the box, but dense mixes don't. This is why. I mainly track in Pro Tools HD, where there is a peak hold with a readout in decibels, very handy! I NEVER track hotter than -10dB, and often not above 15dB. Remember, digital zero (depending on calibration) is 14-18 ABOVE 0dB on analog systems. If you track hotter than that, then you are pushing your analog front end hotter than it was ever design to go. Then the audio slams the plugins, which often add more level. Then the mix bus gets slammed. If you record at more reasonable levels, the mix bus issue goes away. Then it just comes down to skill, just like it always has
I hope I have shed some light on this.
BTW, you might ask, how do I get my mixes loud then? With a peak limiter on the master. Make up your gain there, and NOT prior. (Unless you are submitting your mix to a mastering engineer, then don't do even THAT.)
Keep in mind that GS (and the web in general) is filled with have-knowledgeable people, who repeat whatever they think the current party line is. Take it ALL with a grain of salt.
I believe the DP bus is more or less fine. Other factors in mixing (and tracking) count infinitely more.
