Digital Performer 11.32
- waterstrum
Re: DP 11.32
Bummer!
Consecutive note bug is fixed, but it is replaced by a new even more annoying one.
Stuck notes when using guitar synth.
I have to do the "all notes off command" every few phrases.
Works fine in Logic, so I know it isn't the hardware.
New tech note on the way to MOTU.
All is well
Re: DP 11.32
It’s always something.
Re: DP 11.32
WOw. that is wild Dix. Thank you for checking it. Matt at motu confirmed it is broken except on windows machines. Hmmmmdix wrote: ↑Sat Jun 08, 2024 3:22 pmI'm not sure I'm understanding the issue, but with Preview boxes checked in Humanize, Quantize etc. I'm hearing a preview of what Apply will do to the selected MIDI data here. Works with and without Live mode enabled. ...haven't tested all the MIDI Region tools however. Maybe some are working while others are not?
Does it SHOW you the preview on screen to, like in groove quantize should. Changes visibly on GUI the velocity, duration and timings???
Re: DP 11.32
I never use Groove Quantize (i forgot about this feature) but I just checked. Indeed, Preview does NOT work with Groove Quantize. It works with all the other Previewable Region MIDI items from what I can tell. Just not Groove Quantizelabman wrote: ↑Sun Jun 09, 2024 5:35 amWOw. that is wild Dix. Thank you for checking it. Matt at motu confirmed it is broken except on windows machines. Hmmmmdix wrote: ↑Sat Jun 08, 2024 3:22 pmI'm not sure I'm understanding the issue, but with Preview boxes checked in Humanize, Quantize etc. I'm hearing a preview of what Apply will do to the selected MIDI data here. Works with and without Live mode enabled. ...haven't tested all the MIDI Region tools however. Maybe some are working while others are not?
Re: DP 11.32
[/quote]
Thanks dix. Appreciated.
- shansen1
Re: DP 11.32
Pre gen overload in 11.32
No overload in 11.31
Seams like Dp need more power for the added plugins
Mac Pro M1
Mac Pro M1
Re: DP 11.32
HCMarkus wrote: ↑Fri Jun 07, 2024 9:27 pmtoodamnhip wrote: ↑Fri Jun 07, 2024 8:45 pmWe checked and still broken in Live mode or Pre-genlabman wrote: ↑Thu Jun 06, 2024 5:04 am Looking like all the MIDI plugins (groove quantize, humanize etc) are still broken as reported before since v11.3.Meaning the preview buttons dont work. Can anyone else please confirm.
Thinking along these line, has anyone tried turning pre-rendering off (Live Mode) to see if it impacts MIDI Plugin Preview?
- toodamnhip
Re: DP 11.32
A few versions of Dp back, it would sometime work, sometimes not. It kind of drove me nuts as I was looking fro something "different" about when and when not it worked? I guess now it's 100% broken.labman wrote: ↑Sun Jun 09, 2024 5:35 amWOw. that is wild Dix. Thank you for checking it. Matt at motu confirmed it is broken except on windows machines. Hmmmmdix wrote: ↑Sat Jun 08, 2024 3:22 pmI'm not sure I'm understanding the issue, but with Preview boxes checked in Humanize, Quantize etc. I'm hearing a preview of what Apply will do to the selected MIDI data here. Works with and without Live mode enabled. ...haven't tested all the MIDI Region tools however. Maybe some are working while others are not?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Re: DP 11.32
Re: DP 11.32
Long time, no see!
Re: DP 11.32
Well I'll never...
The one and only Magilla.
Re: DP 11.32
A familiar voice from the past!
Re: DP 11.32
Hi MLC!!!
Re: DP 11.32
Dude! Great to see you!
Re: DP 11.32
MLC is in 'da building!
