OS 9 Gray Screen
miller325
Post by miller325 »
Dixiechicken,
Thanks. I went ahead and disconnected both drives and tried to boot to the OS 9 install CD. Still got the gray screen.
Philip
terra
Post by terra »
terra wrote:Icons Problems ? Make a simple Rebuilding in the OS9 (Comand - Option) while it will be giving to the Boot in OS9... the Icons will appear immediately !
good luck...- this happens when you have installed 2 Systems in the same HD.
Miller, you have "interlok@reset 2" ? if yes, this is the Problem..Put in the Trash, Make the Rebuilding...
G4 1.4 Mhz/ 1.5 Gb RAM - iMac 2.1Gh 1.5 Gb RAM - 828 MKII - MTP/AV - DP3 - 2 (Two) SAMPLECELL Cards - MACKIE 32/8 Bus - JBL4333A - YAMAHA NS10M - YAMAHA ProR3 - DBX 160A - OTARI DAT - ADAT XT - VIRUS - TRINITY - Super JD 990 - MO'PHATT - POD Line 6 - BEHRINGER's DEQ2496 / MIC2200 - NEUMANN MIC's and more...
