Guitar Gaz wrote:You say the Song Window is showing its age but even if it is it is still easier than your suggested method above. In the Song Window you can audition different orders of Chunks and then you can merge them into a bigger Chunk if you want to keep that. A helluva lot easier than the method you describe in the Tracks Overview. That seems a contrary way of trying to avoid the Song Window with no great benefit as there is a fair bit of selecting and dragging - Song Window is much easier in my opinion.
Well, look at it this way: I use both. I know both methods inside out. Sometimes I use the Song Window, but more often I use the Chunks, because they are much more convenient for what I may be doing.
If I want to do a full-blown song construction, where I lay down chords in a chunk, bass lines in chunks, melodies, solos, rhythm elements, drums, and so on and so forth, then I'm definitely going to use the Song Window to piece those together. But if I want to add audio tracks to MIDI files, its going to happen in the Tracks Overview Window, just dragging in the magic audio chunk and dropping it in the list. Presto! MIDI with Audio!
Then there are times when I'm working and I want to store a large section for later use. If I am storing just a track, then I use a scratch track to hold it temporarily until I need it. When I've finally finished with all I need it for, I delete the scratch track after copying the contents back to the main body of tracks. But when I have a whole section, maybe comprising 40 tracks or so, for 16 or 32 bars, where do I store that? I'm not going to create 40 scratch tracks! No, I just drag it into the chunks window, name it, and there it sits until I want to drag it back into the main chunk, perhaps repeatedly. That's much easier than going to the Song Window. It's a more appropriate method, given the task at hand.
So, it's not that we disagree; it's just that you may not be looking at all the situations and possibilities which beg for other methods. Having a lot of methods at your disposal, and being able to choose the most appropriate one for various situations, means a better experience in DP.
By the way, it's really not hard to use the chunks that way. If my description sounded complicated, that's my failing as a writer, not the chunks themselves. Nothing could be simpler than selecting what you want, dragging & dropping it in the Chunks Window, and dragging it back when you need it. Of course... there IS the thing about the bug. That didn't used to be a problem.
