OS 10.9.2 Altered MOTU Audio Setup
Re: OS 10.9.2 Altered MOTU Audio Setup
Bowman wrote:I can't remember if this was the case before 10.9.2, but Audio MIDI Setup - Audio Devices - Configure Speakers seems to have usurped the functions formerly available in MOTU Audio Setup.
There it is. Let's see if that works.
Wow! That's good info-- I didn't even know about that!
Is that menu of streams new with 10.9.2? I don't remember seeing that before in anything except DSP-Quattro.
Bowman
Post by Bowman »
No idea. I only noticed it after the 9.2 update. It could have been there earlier; I can be pretty unobservant at times.
iMac Intel Core i5 3.2ghz - 16gb RAM - OSX 10.10.5 - DP 9.01 - Mach Five 3.2.1 - Ethno Instrument 2.0.3 - Kontakt 5.4.3 - 4pre - 828 original - micro express
nk_e
Post by nk_e »
THANKS A MILLION! That was really helpful.
It's also a neat little control panel. Quite flexible and easy to configure especially for surround.
Mac Studio | 96 GB RAM | OS 15.4 | LIVE 12 | CUBASE 14 | DP 11 | MOTU Interfaces | Waaay Waaay Too Many Plug-ins (but I'm improving!)|
http://www.gesslr.com
TinenTech
Post by TinenTech »
James Steele wrote:Well good thing for me is I had an RTF file that was just printed documentation of my setup and after I enabled the correct ins and outs, all was well. ...
Now THAT is a good idea for backup that I haven't been doing.
It's worthwhile reading these threads even though I haven't upgraded to Mavericks yet.
Has anyone closed the Tech Support ticket with MOTU so they know about this?
MacBook Pro 9,1 (mid-2012 Core i7 2.3 GHz 4 GB RAM), OSX 10.11.3, Newertech Voyager SATA drive dock
MOTU: DP 9.02, Traveler Mk 1, 896 MkIII Hybrid, MIDI Express XT
Alesis AI3 optical interface, QS8, QS7, DM Pro, DM5, QSR
Mackie Controller and Extender (original MIDI)
Pro Tools 12
TheWire
Post by TheWire »
I am in touch with Motu. They were not aware of this Problem. Let's see where this goes. I'll update as I have news.
Update 2014-03-07: They confirmed the issue with 828mkII. 828mkIII is not concerned. Since there is an upcoming music fair at frankfurt it will very likely take 2 weeks until action on this will happen.
828mkII FW, 8Pre FW
GameAudioGuy
Post by GameAudioGuy »
I had the same problem. No configuration within the MOTU device under Audio Devices was working, and I was not getting ANY output whatsoever. Here's how I got it working:
- Within "Audio Devices" create an "Aggregate Device"
- Select the box next to "MOTU 828mk2" to enable it within the aggregate.
- Enable the Input and Output Channels you're using by clicking the numbers and naming them appropriately.
- Setup the default Output in the "Configure Speakers" window by checking either "Main Out" or "Analog"
Here's the interesting part... I found that if I DELETE the Aggregate Device, the audio will continue to push through whatever output I had selected before deleting it even though another device is now selected as the default I/O. When this happens, nothing I change within the "MOTU 828mk2" device will have any effect on the output routing. But... if I just keep the Aggregate there and have it selected, I can just make any adjustments from within there with no issue. I'm now up and running with Logic Pro X and can get back to work, yey!
Also, I don't know if it's worth mentioning that I'm running a Hackintosh :arrrr:
Hope this helps! Cheers.
-B
stephentayler
Post by stephentayler »
My Ultralite Mk 3 is fine, but my original Traveler acts like the above examples.
SWT
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
ALTOIDS
Post by ALTOIDS »
http://cdn-data.motu.com/downloads/audi ... _60625.zip
Enhancements introduced in version 1.6.60625 (3/17/2014):
• Restored Default Stereo Input and Output module.
• Changed the default value for faders on the MicroBook II to be nominal gain.
• Fixed Phones Assign menu ordering issues for 828mk3 family of products (828mk3, 828mk3 Hybrid, and 828x).
GameAudioGuy wrote:Also, I don't know if it's worth mentioning that I'm running a Hackintosh :arrrr:
Welcome to the board. We don't really condone Hackintosh stuff here on this board. It is a violation of the MacOS software license. I know many people do it, but the existence of the pirate emoticon on this board should not be construed to mean that this board condones any sort of piracy. I delete and ban software pirates when it's obvious they're using pirated copies of DP or other music software. I'm NOT saying you're doing this, but the Hackintosh thing is really kind of "iffy" here and I wouldn't boast about it on this board.
songshark
Post by songshark »
ALTOIDS wrote:http://cdn-data.motu.com/downloads/audi ... _60625.zip
Apolologies for my ignorance, but rather than try to understand what the problem was with 9.2 and my 828mkII -- I simply held off on updating to 9.2. Does this new driver solve all the problems -- am I now safe to upgrade to 9.2 as long as I use this new driver? Thanks!
The driver restores the functionality for the affected machines. At least it does for my 828mkII.
Bowman
Post by Bowman »
And for my 828 original.
zuul-studios
Post by zuul-studios »
Thankfully, the new update worked for my 2408 MK3 on the MacPro, and the 828 Mk3 on the MacMini. (Next time, I'm going to be careful when updating the OS.)
Computer:
Apple's M2 Mac Studio with 96 RAM; macOS X 14.5; 1 Internal SSD, 8 External SSDs, MOTU 828es audio device, AKAI MPK88 Keyboard Controller
Software:
DP11.31, Logic Pro X, FCPX, DaVinci Resolve; VSL's Super Package, VEPro 7 & MIR Pro, VI Pro 2; Altiverb 8; Cinesample's CineSympnony Complete Bundle; Native-Instrument's Komplete 13 Ultimate Collectors Edition, and many more VIs.
