The DP 8.06 Bug Report Thread
Killahurts
Re: The DP 8.06 Bug Report Thread
Post by Killahurts »
MIDI Life Crisis wrote:
Guitar Gaz wrote: And it crashed on Quit.
Most troubling...
I was having crash on quite a lot with 805, particularly with projects that have lots of samplers/RAM use. But 806 seems to have fixed it for me..
and to break it for some and fix it for others is also, most troubling.
csiaudio
Location: Indiana; Where the corn is tall and the women are wide!
Post by csiaudio »
There has been a common function of every software that I have ever used over the past 15+ years that has been missing from DP 8 since it's release.
Try this it won't work. Copy a word document file name (or anything for that matter) and then try pasting that file name as a new DP project name. This has been a function of every DP version before 8 but this simple function has been MIA since the release of DP8. MOTU has been aware of this since it's release but they have yet to fix this.
It may seem like nothing to you but when you have to copy and paste client script names to identify the project 50 to 100 times a day it becomes a major PITA.
Of course I'm sure this function isn't an issue for most DP users but why is this common function being overlooked by MOTU? Like I said, I don't know of any software that doesn't allow you to paste something thus allowing you to create a project name.
Capturing the Colors of Sound!
Mac Mini M1 2020 -- DP 11.2 -- Universal Audio Apollo Quad -- Apollo Twin -- SPL Kultube Compressor -- Slate Virtual Mic -- Eve SC207's w/KRK Sub
csiaudio wrote:Try this it won't work. Copy a word document file name (or anything for that matter) and then try pasting that file name as a new DP project name.
Copy and paste doesn't work for me either. But, I am able to drag selected text from a Textedit window to the save dialog box and drop it into the filename field. You have to erase the default "untitled" name first.
guitardood
Post by guitardood »
Hi All,
Just stumbled on a problem today. This was all working on 8.05. MacPro 12-core, MOTU PCIe424, UAD2. S-80 plugged into MIDI timepiece and Yamaha Motif via its USB interface.
I created a new project, 2 tracks, 1 MachFive and 1 MIDI source for MachFive. When I play the piano, the MIDI notes are getting dropped, cut-off and delayed, no matter which sound bank I have loaded. Very strange.
So I created another new project with only 1 MIDI track with its output to the Motif XS and put it in RECORD mode so as to get the MIDI thru. I get the same performance/sluggishness as with the soft synths. I tried another MIDI interface for the input, same results.
I've tried multiple settings on the MIDI-Thru settings in DP to no avail. Any help anyone could provide would be greatly appreciated.
________________________________________________________________________
Best,
Guitardood
Chuck Fletcher on Reverb Nation
Chuck Fletcher on Facebook
"Life is like a box of chocolates. You know, eventually you're going to get the one filled with alien-like nasty tasting goo and have to spit it out and say YUCK".
BKK-OZ
Post by BKK-OZ »
Weird thing - I am running DP up on my new MP, and though it is working fine, for some reason it is not picking up Mach 5.
I have installed Mach 5 (inc. the new update) on the new MP.
I can start Mach 5 as a stand-alone app, it is recognized within Maschine (and in fact, within Maschine running within DP), but DP is not seeing it and doing the AU validation thing. The component is in the folder it should be in, but... nada.
I am going to delete the preferences file and see what happens.
Cheers,
BK
- M Kaku
BKK-OZ
Post by BKK-OZ »
hmmm... can't find a preferences file for DP, I always thought it would be in Library>Preferences, but there is nothing there.
Weirder and weirderer...
I am going through and installing my plugs on my new machine one-by-one.
So far, 'Pancake2' (Cable Guys) and 'Latency Fixer' (Expert Sleepers) are not being picked up by DP's AU validation process, even though the components are where they should be. hmmm...
Cheers,
BK
- M Kaku
Dan Worley
Post by Dan Worley »
BKK-OZ wrote:hmmm... can't find a preferences file for DP, I always thought it would be in Library>Preferences, but there is nothing there.
Are they 64-bit plug-ins?
If so...
/User/Library/Preferences/Digital Performer™ (it's a folder)
You'll want to trash "Audio Unit Info Cache." That will force all AU components to be rescanned and validated when you launch DP.
Many times it's permissions that causes these problems when you move from one computer to another, so you may have to do something about that if rescanning doesn't do the trick.
DP10.13
BKK-OZ
Post by BKK-OZ »
They are 64-bit plug-ins?
If so...
Thanx - yes, all 64bit (all brand new, M5 3.21, etc.).
My user folder does not have a library sub-folder.
The Library>Preferences folder doesn't have a Digital Performer folder. Hmmm...
Cheers,
BK
- M Kaku
Dan Worley
If so...
The Library is invisible by default.
One quick way to get there is to click on the Go menu and hit the Option key, that will toggle it on in the menu so you can select it.
You'll want to set the Finder preferences so it shows all the time. From any finder window, click on the Gear thingy in the toolbar and select View Options. You can make the Library visible from there.
DP10.13
BKK-OZ
Post by BKK-OZ »
You, my friend, have now earned yourself many beers, karmic good-luck points, or whatever else floats your boat. Name yer price!!! Thanx!!
Only by going to the Go menu, then toggling the option key, did the option for seeing 'library' come up in the Finder windows settings dialogue.
I had looked there first, thinking just that - maybe the library was hidden for some silly reason, but the tick box for library doesn't show up, unless you are looking at the library. Of course, that makes sense, right?
Geez, crazy!
Now Mach 5 shows up, but if I instantiate a 5.1 version, it causes DP to crash. [DP 8.06, 10.9.2, M5 3.2.1]
Oh well, part of the way there. I'll raise a tech note with Mr Motu tomorrow, I am too frazzled to keep going tonight.
Thanx again Dan.
Cheers,
BK
- M Kaku
Dan Worley
BKK-OZ wrote:You, my friend, have now earned yourself many beers, karmic good-luck points, or whatever else floats your boat. Name yer price!!! Thanx!!
Geez, crazy!
Thanx again Dan.
My pleasure. Blaze that trail, brother.
DP10.13
michkhol
Post by michkhol »
DP 8.06 crashes on project open more often than not, either without reason or due to problems with Mach Five v3 plugin. The next try is usually successful.
Does not automatically update waveforms anymore (shows just a colored stripe) in case the underlying file is changed by a third-party program (DP was closed at the time of change).
MacPro, 32 GB RAM, Metric Halo ULN8
macOS 13.6.3, DP 11.3
In Mavericks, you can check a box to make the User Library visible permanently. Open your user folder, Get Info and you'll see the box.
In OS 10.7, 10.8 and 10.9, the following Terminal command does the same thing. Paste the following into Terminal and hit the return key:
chflags nohidden ~/Library/
Phil O
Post by Phil O »
I haven't had any crashes in 8.06 (64 bit), on quit or otherwise. Was on OS 10.9.1. Just recently updated to 10.9.2.
Phil
guitardood
guitardood wrote:Hi All,
Please disregard above. Found the problem to be a stuck button on the S-80 which was flooding MIDI controller data. Once clear, DP 8.06 on the latest mavericks seems to be rockin!!
Thanks for listening and thanks to MOTU for some awesome products. :)
Best,
Guitardood
