williemyers wrote:Shoosh, I've never heard the expression keyboard "focus" before, but if it means whether or not an app can "see" (and repsond to) the computer kybd., then I'm in agreement with you here! And, with others that have noted that the problem goes intermittently back in to 7, as well. I have also tried all of the work-arounds that were suggested - usually the click-on-the-desktop-then-click-back-in-a-DP-window thing would work...*usually*...Shooshie wrote:In retrospect,...It's a problem with keyboard/menu focus, ...
But the odd thing for me has been that sometimes, in order to do the above, I would have to click in the desktop area of my *2nd* monitor, then click back on my Tracks Overview window in my primary monitor, in order to get DP to "see" the kybd again. That always did work, but was a bit of a workflow buster. Hope MOTU will have a good look at this...
Hi Willie. I don't know if "focus" is the right terminology for this. It's just what popped into my head when I was typing, and I didn't stop to question it.
The current problem is not the same as previous ones, at least, so I believe. At least, I can say with certainty that the old workaround doesn't work now. So far, the ONLY workaround I've seen that actually works is to reboot the app, and that's a pain in the app.
Me either. In fact, I never had any kind of problem in DP7 that I can remember. None. No crashes, quits, dropped audio… nothing. That was the most enjoyable couple of years of working in DP that I can ever remember.buzz smith wrote:I don't recall having any "focus" issues with DP 7 at all.
Bob, try leaving DP idle in the background for a half hour or so while you are surfing the forum. Then go see if you can click in a track and COMMAND_A to select all.BobK wrote:I haven't spent a lot of time with DP 8 yet, but so far I haven't had any of the issues you mentioned, Shoosh. I just ran through the list, and all is well. Maybe my working sessions haven't been long enough for them to show up - just now I was futzin' around for about 50 minutes.
Shoosh
