Page 3 of 3
Re: Avid Artist series and DP
Posted: Fri Jan 17, 2014 7:20 am
by Vadimoka
try this option.
I installed the new driver from Avid 3_01. installing from a change in the internal firmware - the main thing is not to turn off during the upgrade.
after installing the controller stopped seeing in the program Digital Performer 8.05.
solved the problem - re-installing Digital Performer. It works!
Posted: Fri Jan 17, 2014 10:54 am
by brianbotkiller
You should never turn off your surface during a firmware upgrade. That will brick it.
Posted: Fri Jan 17, 2014 2:03 pm
by Vadimoka
I did not turn off. and write about it. but after installing the firmware and Artist Mix driver stopped seeing Eucon in DP. DP had to reinstall the program again, and everything worked as it should!
Posted: Wed Jan 22, 2014 11:23 am
by buhardilla
Vadimoka wrote:DP had to reinstall the program again, and everything worked as it should!
Every time you install a new version of Eucontrol driver the Avid installer delete the Eucon.bundle native version installed by MOTU Digital Perfomer. This Eucon-adapter is placed in Macintosh HD>Librery>Audio>Plug-ins> MOTU Control surface. Do a copy of this folder the first time that you install Digital Performer and keep it so next time that you need to reinstall the Eucon driver you won't need to reinstall DP: just delete the Eucon.bundle adapter installed by Avid and drag the original Motu Eucon.bundle to this folder.
