Babz wrote:I'd like to see DP's Take interface improved (Take folders, like Track folders). I'd also like to be able to highlight different sections of Takes and then have DP automatically bounce that into a comp in one step, similar to what you see at the end of this video.
DP's Take interface is great when you're tracking, but not so great when it comes time to sort through all those takes and create a comp. Expandable Takes folders and Comp From Selections In Multiple Takes... These two features are at the of my DP 6 wish list.
Babz
Babz, you won't get many arguments that the take system couldn't do with a make-over around these parts.
Tracking is simple and intuitive, but compiling takes efficiently seems to require all sorts of creative approaches.
AscendingMusic wrote:...such as the lack of a decent GM instrument, which is really useful for quick draft arrangements.
One of my long-time dreams for DP, AscendingMusic.
Thanks for the excuse to push MOTU yet again with a 4th August submission I seem to keep throwing at them:
NEXUS - DP's Bread & butter VI module:
1) "Low CPU" mode.
2) Simplified versions of MOTU's existing (synth) techniques.
3) All instruments slected for musicality and usefulness.
4) Provides musical acoustic 4-layer drum & percussion.
5) Uses 4-layer trimmed-down versions of sounds from Ethno & MSI.
6) Offers drag-and-drop sample, Apple Loop, REX etc. functionality, including any Ethno-employed techniques.
Alternatively, the Orchestral and percussive elements could be split into seperate VIs, but that would just be more work for MOTU both initially and in terms of mainetenance.
CONVERB - DP's high-end reverberation engine:
1) "Low CPU" mode.
2) Employs techniques used in MSI.
3) Sensibly sized IR library.
4) MSI convolution library included.
DeePchannel - DP's NEW high-end channel-strip.
1) "Low CPU" mode.
2) Musical compressor with choice of useful vintage behaviours.
3) Musical limiter.
4) De-esser. In this day and age, much more could be done here!
5) EQ with MWEQ topological options.
etc. etc.
One wonders how far off this stuff is.
There should be no doubt it's coming.
