Page 14 of 15
Re: Euphonix DP Update
Posted: Mon Dec 14, 2009 8:03 am
by chaim
I assume you guys are not driving large sessions then....Huh?
What buffer?
Posted: Mon Dec 14, 2009 8:28 am
by labman
chaim wrote:I assume you guys are not driving large sessions then....Huh?
What buffer?
I agree Chaim. 75-100 tracks of orchestration@512 buffer renders a macpro quad shaky at best here. When it was hovering around 30-35% before turning on Eucon.
Posted: Mon Dec 14, 2009 8:45 am
by KEVORKIAN
What buffer?
1024 buffer.
I'm doing band mixes that are generally around 30-50 tracks. I have, V-racks, VI's and plenty of effects going. Without Eucon, the Mac Pro is in the 75% range max, with Eucon I see frequent peaks, however playback is unaffected.
Posted: Sat Feb 27, 2010 10:43 am
by KEVORKIAN
I use a MIDI controller for punching in and out of DP usually. However, I just tried to use the footswitch jack on my MC Control to punch in/out of DP and it doesn't appear to be working correctly.
I just tested the footswitch on DP 6.02, 7.0, 7.02 and 7.1 and all I can get it to do is punch in.
It will not punch out in any version of DP for me.
I tried the same EuControl footswitch settings in Logic 9.1 and Live 8.1.1 and I can get both of those apps to both punch in and out using the footswitch.
I'm hoping someone else can test this.
Posted: Tue Mar 02, 2010 4:49 am
by dgraf
Just updated to DP7.1 this weekend, and all seems to be going well with my MC Mix and MC control setup. EXCEPT... when I have multiple inserts on a channel, and I push the insert button, then push the button for the appropriate insert, no matter which insert I choose, the 1st insert graphic interface pops up on the screen! The controls which come up on the MC control are the correct ones for the insert I selected and they do indeed control the correct insert. I can go to DP and select the right graphic interface. Am i missing a setting somewhere or is this a bug that any of you have run into? According to the docs, as I understand them, when you select any insert, its user interface is supposed to come up.
Posted: Sun Mar 07, 2010 5:37 am
by dgraf
Update - I have done a little more testing, and have found that the input buttons work as promised in logic. It seems to be DPs implementation of Eucon that has the "bug". Anyone else that can confirm (see my previous post)? Definately not a deal breaker though. I really love this control surface.
Posted: Sun Mar 07, 2010 6:31 am
by chaim
Still waiting for either motu or euphonix or both, to fix the cpu killer - bug.
DP 7.1 with EuControl 2.5.2 still no good.
Posted: Wed Mar 17, 2010 9:18 am
by chaim
Just released:
EuControl Software Package Version 2.5.4
Mac OSX
Software update for MC Color, MC Mix, MC Transport and MC Control that expands Aux to Faders Soft Key functionality in Pro Tools to all tracks, fixes Pro Tools Pan and Aux knobs, includes new Soft Key applications sets for Apple Motion and Adobe After Effects 9.0, updates application sets for Nuendo 4, Cubase 5 and Logic Pro 9, improves MC Transport Wheel functions on the shift layer, and includes several performance improvements that include improved stability, faster Knob Set loading, and more.
Version 2.5.4 also gives MC Color cross-application Soft Key support, better navigation of Color secondaries, and copy/paste grade functionality for Apple Color Memory Bank 5.
Intel & Power PC Macs running OSX 10.5 and higher.
Posted: Wed Mar 17, 2010 11:58 am
by delcosmos
Does anybody knows if they fixed the "Punch out" and processor spikes problems on DP?
Best regards.
delcosmos.
Posted: Wed Mar 17, 2010 12:04 pm
by sourgrapes
dgraf wrote:Just updated to DP7.1 this weekend, and all seems to be going well with my MC Mix and MC control setup. EXCEPT... when I have multiple inserts on a channel, and I push the insert button, then push the button for the appropriate insert, no matter which insert I choose, the 1st insert graphic interface pops up on the screen! The controls which come up on the MC control are the correct ones for the insert I selected and they do indeed control the correct insert. I can go to DP and select the right graphic interface. Am i missing a setting somewhere or is this a bug that any of you have run into? According to the docs, as I understand them, when you select any insert, its user interface is supposed to come up.
Yes this is also happening for me - however I've found that if you move one of the control knobs on the MC Control for any one of the parameters of the desired plug (not the one that graphically appears at first), the desired plug will then appear on top of the other and all functions normally afterward - weird I know, at first I thought I was doing something wrong but i guess for now that's just how it is...
Posted: Wed Mar 17, 2010 12:30 pm
by toodamnhip
Can one "RIDE" an EQ boost within an EQ plug with this controller?
Or ride any plug in parameter for that matter?
Posted: Wed Mar 17, 2010 9:12 pm
by burn em
toodamnhip wrote:Can one "RIDE" an EQ boost within an EQ plug with this controller?
Yes. You can also do this with a fader.
Posted: Thu Mar 18, 2010 2:06 am
by martian
and how well? for example - I CAN do it with my HUI - but it's slow compolicated and not always responsive..
faders are much better tho..
i just wished I could get a demo to try out with my rig- I could see myself buying 3 of them if it worked...
Posted: Thu Mar 18, 2010 3:04 am
by toodamnhip
burn em wrote:toodamnhip wrote:Can one "RIDE" an EQ boost within an EQ plug with this controller?
How well does it work and how well would you guess in DP 5.13 running OS 10.4.11
Posted: Thu Mar 18, 2010 4:09 am
by dgraf
sourgrapes wrote:dgraf wrote:Just updated to DP7.1 this weekend, and all seems to be going well with my MC Mix and MC control setup. EXCEPT... when I have multiple inserts on a channel, and I push the insert button, then push the button for the appropriate insert, no matter which insert I choose, the 1st insert graphic interface pops up on the screen! The controls which come up on the MC control are the correct ones for the insert I selected and they do indeed control the correct insert. I can go to DP and select the right graphic interface. Am i missing a setting somewhere or is this a bug that any of you have run into? According to the docs, as I understand them, when you select any insert, its user interface is supposed to come up.
Thanks for the workaround - I will give this a try.
