Euphonix DP Update
chaim
Re: Euphonix DP Update
Post by chaim »
I assume you guys are not driving large sessions then....Huh?
What buffer?
Mac Pro 2X quad core 2.26 Ghz, 22 GB RAM, OS 10.8.4 | DP 8.05 | 2408MKII
Beta Tester for Toontrack
labman
Post by labman »
chaim wrote:I assume you guys are not driving large sessions then....Huh?
What buffer?
I agree Chaim. 75-100 tracks of orchestration@512 buffer renders a macpro quad shaky at best here. When it was hovering around 30-35% before turning on Eucon.
KEVORKIAN
Post by KEVORKIAN »
What buffer?
1024 buffer.
I'm doing band mixes that are generally around 30-50 tracks. I have, V-racks, VI's and plenty of effects going. Without Eucon, the Mac Pro is in the 75% range max, with Eucon I see frequent peaks, however playback is unaffected.
dp7.2 || os 10.6.7 || 2x2.8 (eight core) intel mac pro, 16gb ram || metric halo uln-8 || motu traveler || euphonix mc control || waves mercury || abbey road bundle || mh channelstrip || toontrack sd 2.0, ez drummer, drumtracker || addictive drums || drumcore 3 || ni komplete 5 || reason || bidule || altiverb 6 || omnisphere, stylus RMX || melodyne 3.2 || stillwell || soundtoys || nomad factory|| psp || mpressor || dsm ||
KEVORKIAN
Post by KEVORKIAN »
I use a MIDI controller for punching in and out of DP usually. However, I just tried to use the footswitch jack on my MC Control to punch in/out of DP and it doesn't appear to be working correctly.
I just tested the footswitch on DP 6.02, 7.0, 7.02 and 7.1 and all I can get it to do is punch in.
It will not punch out in any version of DP for me.
I tried the same EuControl footswitch settings in Logic 9.1 and Live 8.1.1 and I can get both of those apps to both punch in and out using the footswitch.
I'm hoping someone else can test this.
dgraf
Post by dgraf »
Just updated to DP7.1 this weekend, and all seems to be going well with my MC Mix and MC control setup. EXCEPT... when I have multiple inserts on a channel, and I push the insert button, then push the button for the appropriate insert, no matter which insert I choose, the 1st insert graphic interface pops up on the screen! The controls which come up on the MC control are the correct ones for the insert I selected and they do indeed control the correct insert. I can go to DP and select the right graphic interface. Am i missing a setting somewhere or is this a bug that any of you have run into? According to the docs, as I understand them, when you select any insert, its user interface is supposed to come up.
Imac 27" core i7 (3.5ghz), 15" Macbook Pro 2.8ghz Core 2 Duo, UA Apollo Quad 800 firewire, Mackie Onyx 400f firewire,Euphonix MC Control, Euphonix MC Mix, DP 8.04 , Logic 9. AMPGUI Mods "Sharp", "Dark", "Snow", "Mellow"(electric blue).
dgraf
Post by dgraf »
Update - I have done a little more testing, and have found that the input buttons work as promised in logic. It seems to be DPs implementation of Eucon that has the "bug". Anyone else that can confirm (see my previous post)? Definately not a deal breaker though. I really love this control surface.
chaim
Post by chaim »
Still waiting for either motu or euphonix or both, to fix the cpu killer - bug.
DP 7.1 with EuControl 2.5.2 still no good.
chaim
Post by chaim »
Just released:
EuControl Software Package Version 2.5.4
Mac OSX
Software update for MC Color, MC Mix, MC Transport and MC Control that expands Aux to Faders Soft Key functionality in Pro Tools to all tracks, fixes Pro Tools Pan and Aux knobs, includes new Soft Key applications sets for Apple Motion and Adobe After Effects 9.0, updates application sets for Nuendo 4, Cubase 5 and Logic Pro 9, improves MC Transport Wheel functions on the shift layer, and includes several performance improvements that include improved stability, faster Knob Set loading, and more.
Version 2.5.4 also gives MC Color cross-application Soft Key support, better navigation of Color secondaries, and copy/paste grade functionality for Apple Color Memory Bank 5.
Intel & Power PC Macs running OSX 10.5 and higher.
delcosmos
Post by delcosmos »
Does anybody knows if they fixed the "Punch out" and processor spikes problems on DP?
Best regards.
delcosmos.
8.07 64bit, Spire, Nexus, Fab FilterDiva, Gladiator, Nexus, Sylenth, Stylus RMX, Live 9, Reason 6.5, Komplete 8, AD Keys, AD Drums, Geist, Ivory, Waves 9 Mercury, Sound Toys, Fab, VEPro, Reason, Live, UAD2, x3 2408mk3, PCI424, MAC PRO Dual 3.46 Ghz 12 core Intel Xeon, Memory: 64gb ram, MAC OS X: 10.8.6
sourgrapes
Post by sourgrapes »
dgraf wrote:Just updated to DP7.1 this weekend, and all seems to be going well with my MC Mix and MC control setup. EXCEPT... when I have multiple inserts on a channel, and I push the insert button, then push the button for the appropriate insert, no matter which insert I choose, the 1st insert graphic interface pops up on the screen! The controls which come up on the MC control are the correct ones for the insert I selected and they do indeed control the correct insert. I can go to DP and select the right graphic interface. Am i missing a setting somewhere or is this a bug that any of you have run into? According to the docs, as I understand them, when you select any insert, its user interface is supposed to come up.
Yes this is also happening for me - however I've found that if you move one of the control knobs on the MC Control for any one of the parameters of the desired plug (not the one that graphically appears at first), the desired plug will then appear on top of the other and all functions normally afterward - weird I know, at first I thought I was doing something wrong but i guess for now that's just how it is...
Mac Pro 2.8 8 Core / 18G RAM / 10.6.2 / DP 7.21 / FCS 2 / UAD 1+2 / Waves Renn Maxx / Waves Gold / Komplete 5 / EWQL Play / Samplemoog / Sampletron / Stylus RMX / GForce Future Retro / Guru / Lounge Lizard EP-3 / Kore 2 / Ampeg SVX / Reason 4 / Arturia 10 Year Suite / Izotope Ozone 4 / 828mkII / 8Pre / KRK VXT4 / BlueSky Sub8 / Lavry Blue AD/DA / Euphonix MC Mix and MC Transport...and one beautiful 1982 Prophet 5 Rev 3.3.
toodamnhip
Post by toodamnhip »
Can one "RIDE" an EQ boost within an EQ plug with this controller?
Or ride any plug in parameter for that matter?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
burn em
Post by burn em »
toodamnhip wrote:Can one "RIDE" an EQ boost within an EQ plug with this controller?
Yes. You can also do this with a fader.
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
martian
Post by martian »
and how well? for example - I CAN do it with my HUI - but it's slow compolicated and not always responsive..
faders are much better tho..
i just wished I could get a demo to try out with my rig- I could see myself buying 3 of them if it worked...
macpro 3 gig - 5 Gig RAM 10.6.3 Motu 2408 mk 2 Mackie HUI DP 7.21 intel imac 3 gig ram traveller OS 10.6.3
http://www.fork-media.com
toodamnhip
How well does it work and how well would you guess in DP 5.13 running OS 10.4.11
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
dgraf
Post by dgraf »
Thanks for the workaround - I will give this a try.
