dewdman42 wrote:I do like Logic's piano roll better, but I'm not a DP piano roll guru to comment about functionally either of them can do. I just like the way it looks on Logic. IT FEELS nicer to me. I don't like the way DP's looks. It irks me. Not sure why exactly. I also like the way Logic's regions seem to line up on bar boundaries better. while the regions in DP seem just kind of random the way they outline the notes, with the region boundaries having no musical significant whatsoever. So in logic its super easy to end up with bar-dilineated regions that can easily be looped, aliased, copy and pasted, dragged around, etc...in a musical way...whereas DP's regions feel like just meter-less regions of notes with no musical timing meaning to them. I find Logic's ability to slap bits of audio or MIDI into the arrangement window and loop them out or whtaever, very easy and intuitive and musical..more like Live and Bitwig, Project5 and others... I feel DP loses on that front.
If I had to try to label things, I would call Logic a musicians dream and an engineer's nightmare and DP the other way around, though in both cases, neither one is truly a nightmare. but I just think DP has really thought though many engineering issues and provided solutions and a clean tracking environement, while they've kind of gotten long in the tooth in the music writing and composing area of the product. DP is not as innovative in terms of providing tools to create music with. Its all there, you can do it, but its not as musically intuitive is all.
I appreciate all the time you spent both in trying Logic and comparing it to DP, as well as in writing it all down for us. That's good conversation whether I agree or disagree with the quote above. Of course, I wouldn't be prefacing it this way if I totally agreed. Back in Logic 8 Studio, I spent the better part of a year going back and forth between DP and Logic, trying my best to get up to speed in Logic as regards MIDI recording, composition, and editing. I had to conclude that Logic was designed by people who never really understood the musician's needs or ways of working creatively. People say it's better now than it was then; I wouldn't know about that. But as of Logic 8, it did not hold a candle to DP's MIDI workflows, other than in working with pre-recorded loops. (which I never use)
The Regions in DP are not as powerful or convenient as those in Logic, but for the most part I work with selections rather than regions. However, it DOES get a bad rap. People rarely pay close attention to the region parsing preferences in DP. It's a two-part thing. If the region is longer than X beats, you have it parse them into regions of Y beats in length. That's not as useless as everyone makes it out to be. You have to play around with both X and Y to see what offers you some functionality.
You did not mention the Tracks Overview Window in DP. It has no analog in Logic, and is one of DP's greatest strengths. If you learned DP back before the Tracks Overview window (graphic interface) existed, your workflow evolved with that window. In the early 1990s, it did not even show you any notes, just shades of gray to indicate how much MIDI activity was in each cell. But you learned that by changing the resolution of the window, you could work wickedly fast moving bars around, or partial bars, or beats (all in the resolution). That capability is still there today. It's in learning the keyboard commands, setting up some that help you out, and learning the differences between range and event selection, and how to use them.
The piano roll in Logic seemed too coarse for me. I like DP's, which I can set for any resolution, and with which the controllers for the active track are always visible and aligned with the notes, or easily filtered with Quickfilter. Logic makes you jump through hoops to do that. The DP MIDI drawing tools are infinitely superior than Logic's, IMO. Again, it's about learning, setting up and using keyboard shortcuts. The SOLO command in the MIDI Edit Window enables you to click a track and hear it or any combination of tracks made visible in the window. That's quick setup for hearing what you're working on, comparing it with other tracks, etc.
I made my living for over 20 years with MIDI, and added audio to my work when it became available natively on the Mac. But for at least 15 years, MIDI was my bread and butter. I worked fast, and could create expressive scores very quickly.
"Expressive" is the keyword there. Logic defied me to be expressive. It was so much damn work in Logic to create expressive lines during the editing and mixing stages that I finally just pushed it aside and decided DP was always going to be my main axe, period.
Everyone has their own ways of working, and if Logic fits someone, I'm not going to criticize them for it. But I'm an old-school composer and arranger with very fine performance skills as well, and for me, DP was the only real way to get anywhere. It's just a matter of keeping the score in your head so you always know where you are, and learning to work with selections rather than regions. Selections can do anything. Regions (in Logic) tie your hands more often than they help. It's the "group" that wouldn't go away! I mean, groupings are nice, but usually I'm not editing the group. I'm editing the contents of that group. Regions are just in the way, then. Selections can be made quickly and held for long periods as you work. Much better for me. But that's just me. When I want to move the region, I go to the Tracks Overview Window and work with it. It's still DP's best-kept secret, and a powerful, fast window for editing and doing all kinds of work from hands-on data moving and selection to utility work for I/O, track naming, record enabling, song building, large structural changes, drag & drop sections to/from chunks or Finder, and much, much more.
I could write a book about MIDI in DP, and if you took the many posts i've made here on the subject, I'm sure they could be turned into a book, but I won't do that tonight. Suffice to conclude that working with MIDI in DP is one of those things that makes me pinch myself to see if I'm dreaming, because it's exciting and fun. I still can't believe I made a career of it. I was a performer who thought that MIDI would make it easier for me to transcribe, edit, and transpose scores. Suddenly I found other people offering me too much money to refuse if I did those things for them, too. I tried a few other platforms over the years, but they just didn't have the depth of DP, housed within clean lines and clear functions, with the ease of use.
