How many folks are using DP Mixerless?
wylie1
Re: How many folks are using DP Mixerless?
Post by wylie1 »
Thanx again Buzzy:
I'm hoping to have everything back up and running by tomorrow.
I'm a little intimidated by Cuemix.
wylie1
Post by wylie1 »
HCMarkus wrote:
wylie1 wrote:
HCMarkus wrote:Presonus Digimax FS
I thought I've look at everything.
This is what I've been looking for.
Thanx to everyone for posting details I've learned allot here.
I clock my 828 from the FS using the wordclock. A short BNC cable is all that is required. I use the FS I/O as my primary I/O, and it sounds very good.
I'm trying to use the FS as a clock for my 2408km3 but can't seam to get it working.
What setting do I have to change?
I have BNC out on the FS to BNC in on the 2408
danworks
Post by danworks »
wylie1 wrote:I'm trying to use the FS as a clock for my 2408km3 but can't seam to get it working. What setting do I have to change? I have BNC out on the FS to BNC in on the 2408
On DP hardware setup you must set the sync from internal to WC.
Disclaimer: I'm on train, not in front DP, but it should work afair :)
"Leave the gun, take the cannolis …"
#1- MacPro-12Cores 3.3Ghz /64gig RAM/MacOS 10.13.6/DP10/VEP6/PCI-424
#2- MacPro-12Cores 3.3Ghz/64gig RAM/MacOS 10.10.5/VEP6
UAD2 and lots of software and plugs
Solo project here and on iTunes
wylie1
Post by wylie1 »
I'm still missing something.
If I plug into channel 1 on the FS I get a light to bank b on the front of the 2408.
But when I add a track in DP all I see is analog 1-8 I don't see the FS which I assume would show up as ADAT 1-8.
Is that right?
bzfoto
Post by bzfoto »
BOTH, depends on size and situation.
wylie1
Post by wylie1 »
O happy joy I've got everything back on line.
Thanx for all the support I never would have made a change like this with out it.
My brain is still num from working with Cuemix but I can see how it can be used to patch through all kinds of outboard gear.
I thought my system was quite before but now its just crystal clear.
Bye Bye mixer.
:) :D :lol: :mrgreen:
