Pap
Which box is that? Arent you still summing stereo stems, yes? So summing is still something of a compromise isn't it, because it's sort of "partial summing?" I guess it depends on number of inputs, etc. on the summing box?danworks wrote:Money? Who needs money?James Steele wrote:Hmmm... maybe not but my bank account looks better.danworks wrote:Get the three mixes, blind listen to them into a trustful control room and tell me if they sound the sameIf you don't have the dough for the very high quality mixers or summing gear, you're better of ITB.
I understand what you say James, but a decent summing box starts from $1500, which is not like giving away an arm and a leg. I'm sure you'd enjoy a lot, especially if you're one of those guy into the tough rock guitar type of music … aren't you?
Usually a summing box has 8 stereo input (16 channels). The one I use (SUMO) has the possibility to mono-ize channel 1-2 & 3-4. Anyway with 8 stereo I usually splits instruments by family this way:James Steele wrote:Which box is that? Arent you still summing stereo stems, yes? So summing is still something of a compromise isn't it, because it's sort of "partial summing?" I guess it depends on number of inputs, etc. on the summing box?
Sounds like you better call Presonus and ask them what's up. That doesn't sound right. You should at least have meters going. I don't have S/PDIF on my HD192, so I'm connected to it via analog inputs. Also note there are trim pots on the front of the unit I believe for the output level to your monitors, so check that. But you definitely should call Presonus and perhaps get a return authorization.wylie1 wrote:I've got an issue with Central Station.
I've plugged in the CS via SPDIF from my 2408mk3.
When I booted everything up to my surprise audio was passing through the CS I thought I would have to make some kind of change in the 2408 before this would happen.
The issues are.
There are no meter lights on the CS and looking at the wiring diagram it looks like if there audio there should be lights.
Also the output from the CS is week compared to my old board,but that my be normal I don't know.
And theres a POP in one of the headphone outputs when you turn the volume control.
I'm thinking I've got a bad unit here.
Thanks for the explanation. So in essence it's not exactly duplicating an analog mixer, because there is *some* in the box mixing still going on within your stereo "subgroups" as it were. I would imagine the separate reverb return makes a big difference though. Interesting!danworks wrote:Usually a summing box has 8 stereo input (16 channels). The one I use (SUMO) has the possibility to mono-ize channel 1-2 & 3-4. Anyway with 8 stereo I usually splits instruments by family this way:James Steele wrote:Which box is that? Arent you still summing stereo stems, yes? So summing is still something of a compromise isn't it, because it's sort of "partial summing?" I guess it depends on number of inputs, etc. on the summing box?
1 mono lead vocal, 2 mono bass,
3-4 acoustic guitars,
5-6 electric guitars,
7-8 keyboard n stuff,
9-10 drums perc loop etc,
11-12 orchestra (if any),
13-14 sound fx-pad-atmo (if any),
15-16 reverb, delay, echo and whatever else return.
I don't want convince anybody but it simply works very well
Obviously al the mixing movements, automation 'n stuff are done within DP. But then everything goes to the summing box. It's just like having a 16 channel analog mixer with faders set at 0db, with a very big headroom for each instruments family. You can push your level as much as you want, being "almost" without limits cos everything is not going through only two digital outputs (in the box) but split through 8 stereo busses.James Steele wrote:Thanks for the explanation. So in essence it's not exactly duplicating an analog mixer, because there is *some* in the box mixing still going on within your stereo "subgroups" as it were. I would imagine the separate reverb return makes a big difference though. Interesting!danworks wrote:Usually a summing box has 8 stereo input (16 channels). The one I use (SUMO) has the possibility to mono-ize channel 1-2 & 3-4. Anyway with 8 stereo I usually splits instruments by family this way:James Steele wrote:Which box is that? Arent you still summing stereo stems, yes? So summing is still something of a compromise isn't it, because it's sort of "partial summing?" I guess it depends on number of inputs, etc. on the summing box?
I was on the phone with Sweetwater yesterday is sounds like a bum unit.Tonio wrote:eeww, that don't sound good.
Let us know the outcome please.
T
Yes.wylie1 wrote:Are you using Cuemix to handle your external verb?
I've still got to figure that out.
