DP 6.02 is up
davelee
Re: DP 6.02 is up
Post by davelee »
Some strangeness with 6.02.
Working on a new tune. All VI's at this point.
1 instance of the following followed by the # of parts...
Omnisphere-8
RMX-4
Ethno-3
Ivory-1
Real guitar-1
plus 2 Ativerbs and 1 Pro Verb
On playback with 6.01 audio performance is 50-60%
With 6.02 I'm at 90% or higher.
Uninstalled 6.02 and reinstalled with same results.
Repaired permissions and ran disc warrior with same results.
Any comments or help is appreciated.
Mac Mini 2.3 i7 Quad 16 gig RAM OS 10.10.1, Macbook Pro Dual Core 2.16 4 gig RAM 10.10.1, Digital Performer 8.07,Universal Audio Quad, Mackie Onyx 800R, Yamaha Motif ES Rack, Omnisphere, RMX and Trilian,Komplete 9 Ultimate, Ivory I, BFD 2, Korg LCDE, Real Guitar, Real Strat, Ethno 2, Altiverb 7,True Pianos, Synplant, Microtonic, Dynaudio BM6a, Avantone Mix Cubes, Alphatrack, Mackie Big Knob,Yamaha KX-8,Yamaha KX-76,Axiom 25...and more.
kassonica
Re: DP 6.02 is up
Post by kassonica »
blazingrythm wrote:FATAL ERROR!!!?
I just installed 6.02 and when I launched it I got a fatal error pop up.
As it was loading all the plugins the Bias demo bundle with GateX, Squeeze, etc apparently expired
and it gave me the choice of buying or cancel, but for every plugin in that Bias bundle and then crashed.
I tried trashing everything Bias, except for Soundsoap which I've had for a few years and still crashes.
I even tried having the DP6 installer disc in the computer when I launched DP 6.2 and CRASH!
The fatal error pops up after a few plugins get loaded, I click OK and it goes through loading all my plugins and then crashes on me.
Can anyone here please help me?
Thanks in advance,
Robert
Hey Robert take out all your plugins (except the motu ones) put them in the disabled folder in your plugin folder in the library (if there is not a disabled folder just create one) and boot DP. If it boots and all is fine close it, then put one back in and reboot, do this until you find the bad one/s.
Also try deleting the AU cache file in user/library/preferences/digital performer.
Hope you get it sorted
Re: DP 6.02 is up
davelee wrote:On playback with 6.01 audio performance is 50-60%
Did you check to see that some of the instruments did not get changed in their real-time vs. pre-render status? Did all your studio configuration settings remain the same. Just wondering.
kassonica
Re: DP 6.02 is up
Post by kassonica »
i"m finding the opposite really to Davelee. Dp seems much responsive and the CPU hit seems slightly lower.
+1 on the pre render check.
wurliuchi
Re: DP 6.02 is up
Post by wurliuchi »
davelee wrote:Some strangeness with 6.02.
Omnisphere-8
RMX-4
Ethno-3
Ivory-1
Real guitar-1
Take a look at your Hardware Driver config -- Buffer size, Work priority, Multiplier. Maybe something in there got changed or needs to be adjusted. I set the Work Priority to Low and that made a big difference in lowering the CPU usage. It might also be a pre-render or real-time thing with the VIs. I don't know.
DP 6.03 • MacPro 2x3 Ghz Dual-Core Intel Xeon • 9 GB RAM • 10.5.7 • Prayers
Re: DP 6.02 is up
Yeppers... I have my work priority set to "Medium" and it works great. I'm not sure what the big advantage is to setting it to "High?" It's a natural impulse to set it there, but I've found that it doesn't seem to buy me anything.
wurliuchi
Re: DP 6.02 is up
Post by wurliuchi »
James Steele wrote:Yeppers... I have my work priority set to "Medium" and it works great. I'm not sure what the big advantage is to setting it to "High?" It's a natural impulse to set it there, but I've found that it doesn't seem to buy me anything.
I don't even know what Work Priority means in this context, but Magic Dave told me to set it to Low on my PB G4 and it made a big difference, and now on my new machine, it was set to High and I was getting some playback buffer alerts, so I set it to Low and it made a big difference -- like 30% less CPU usage worth of difference.
Armageddon
Re: DP 6.02 is up
Post by Armageddon »
labman wrote:That will be extremely helpful for us here A ! We also have some of those same units.(Lizard, Philharmonik) Did you test out Melodyne plug-in?
Lounge Lizard works great in 6.02, same with Philharmonik and all the other IK plugs! Melodyne Bridge also seems to be working well, at least for me!
Re: DP 6.02 is up
Yeah... I also discovered (not news to some here I know) that you can push closer to the limit on a UAD-1 card if you set your work priority to low also. I may try changing it there now. Again, can anybody name a single meaningful advantage to setting work priority to high??
mhschmieder
Re: DP 6.02 is up
Post by mhschmieder »
Yes, it's snappier :-).
But then, I'm not a very sophisticated user of DP, so my joyful experience with the update last night is probably not representative.
I unfortunately haven't the time to sift through fifteen full pages of posts on a brand-new topic. Has this ever happened before, over just one day?
Dan Walsh
Re: DP 6.02 is up
Post by Dan Walsh »
kassonica wrote:
Maybe start one :D
I kinda want to, but everyone is poppin' in on this one and I'm followin' like a hawk in a field of mice now that I'm caught up. Waddaya think James?? Should I start a new one???
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
kassonica
Re: DP 6.02 is up
Post by kassonica »
Dan Walsh wrote:
kassonica wrote:
Maybe start one :D
DO IT hehehehehe
It seems like quite the bug so I think it deserves it.
Re: DP 6.02 is up
Dan Walsh wrote:
kassonica wrote:
Maybe start one :D
Already did:
http://www.motunation.com/forum/viewtop ... =1&t=34206
In fact this board software has a "Split Topics" function. So I am able to select certain posts and move them into their own topic, which is what I did at the link above. :) I may do this for the Stillwell plugs issue as well.
Dan Walsh
Re: DP 6.02 is up
Post by Dan Walsh »
Cool James. We really appreciate it. I was kinda hopin' that could be done. :D
kassonica
Re: DP 6.02 is up
Post by kassonica »
Dan Walsh wrote:Cool James. We really appreciate it. I was kinda hopin' that could be done. :D
I didn't know about the split topics function but that is cool...
Thanks :D
