DP 4.61 and GPO
dynamix
Post by dynamix »
I hope that somebody has been sharing this on the Garritan Forum...
http://www.garritan.com/forum.html
http://www.dvbmusic.com
Dual 2 Ghz G5, MOTU 896, OS 10.3.9, DP 4.6, Mach 5, Kontakt 2.2, MX4, Reason 3.0.5, GPO, Absynth 4.0.2, B4 Organ II 2.0.3,. MacBook Pro 2.33 GHz Intel Core 2 Duo - 4 GB 667 MHz DDR2 SDRAM w/ MOTU Traveler & MOTU Bag w/ OS 10.4.10, DP 5.12
mhayesmusic
Post by mhayesmusic »
I am looking on the northern sounds forum right now for someone with the same problem myself. I haven't done the upgrade yet either. This could definately put a damper on that. heres the link for those that don't know about it.
http://www.northernsounds.com/forum/index.php
DP 4,G4 DP 1.25 ghz, 1 gig ram,2408 mkI, MTP AV, Reason, Mach Five, iDrum, SoundSoap, Garritan Personal Orchestra,Ptools LE Mbox, Korg Triton, Oxygen 8, M-Audio Pro88 Controller, S4 Plus, FCP,DVD SP and many other goodies with pretty lights
croyal
Post by croyal »
I have the GPO Sampler (selected Instruments only) that came with Finale 2006 . No problems using it with DP 4.61 and Tiger 10.4.3 (the problems are with using GPO and Finale!).
The Kontakt Player is the interface in my case and I use it as I would any other VI. Is this not what happens with the full version of GPO and DP 4.61?
Is Kontakt the plugin interface presented with GPO?
Chris
Mac Studio Ultra/ 2013 Trashcan. DP10 and 11.
32 channels of Apogee Symphony MkII/ Dangerous 2Bus+.
Lots of Neve, API, and Dangerous outboard gear.
bradrose
Post by bradrose »
I have GPO and DP 4.61 with 10.4.3 working OK as described in the tutorial on the Garritan website. This uses the Kontakt player interface that everyone is used to. As I said before, I don't remember what I did to have the patch list show up in DP 4.5, but what the heck as long as it works.
As for my other issue of not seeing the Triton Rack patch lists in DP4.61, that got solved as well, although it was strange. First of all, the AudioMidi setup in 10.4.3 did not even list Korg (or Roland or several others) in the manufacturers pull-down menu. So I aaded a new MIDI device and manually entered "Korg" into the manufacturer box and entered "Triton Rack" in the Model box. Of course, the Triton Rack patch list did not display in DP 4.61 when I clicked on the Patch column of my MIDI track in the track view. SO... I found the MIDI patch list files in /Library/Audio/MIDI Devices/MOTU/Korg and found the patchlist file for the Triton Rack (called Triton-Rack.midnam). I then went back to the AudioMidi Setup and manually entered the patch list file name (Triton-Rack -- no filename extension) into the Model box and clicked APPLY. When I pulled down the manufacturers pull-down list again, lo and behold the AudioMidi setup suddenly listed Korg in the manufacturers pulldown menu AND all the recognized Korg devices showed up in the Model pulldown list. I then ran DP, clicked on the Patch column in the track view of my MIDI tracks and there were all the patch banks and patch lists for the Triton Rack. So if you are not seeing your patch lists in DP with Tiger 10.4.3 when you were seeing them before, try finding your gear's patchlist file and key the exact file name (without the ".midnam" extention) into the Model box in the AudioMidi setup, apply it, then run DP.
