DP11 PERFORMANCE ISSUES
Re: DP11 PERFORMANCE ISSUES
labman wrote: Mon Sep 02, 2024 5:28 am
bayswater wrote: Sun Sep 01, 2024 1:04 pm
I'm don't know what you mean by "front daw". You mean host, or daw like DP or Logic?
Front DAW is a front end simulator by United Plugins i believe. Got it when it first came out. Fairly decent for adding some hair from any of its emulations.
Ah, thanks, I guess I could have looked it up. Is it CPU intensive (if you put it on 128 channels)?
akr
Post by akr »
Yes front DAW Is a front end emulatiin by united plugin
I still cannot understand performance Meter in dp
Even in a project with free plugins
RAL time Meter Is in 50%
Monitor acitivy
DP 105 %
Cpu Activity 12%
I have a 24 cores
Why performance Meter Is @50%?
:banghead:
DP11.31 macPro 5.1 (2012), 4x 8coreXntel Xeon 5690, RAM 128 Gb, UAD 2, Waves 11 Diamond, Izotope Nectar3 & Neutron2, ozone 9 and more....
RMEff800
Have you looked at Effect Performance? Open up a sidebar in the Consolidated window, and add Effects Performance window to see what your plugins are doing. It looks like this.
Screenshot 2024-09-02 at 12.47.49 PM.png (53.41 KiB) Viewed 1042 times
When running it will tell you the resources used by plugins. That might explain what you are seeing.
dwilliams
Post by dwilliams »
Waves NLS is a resource hog. I bought it and can't use it the way I intended. Very disappointing. Try removing it and see what happens.
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 16" M3 Max 16-core 4.05 GHz 48GB 1TB Late 2023 MBP, Sonoma 14.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2, TB hub w/ USB 3.0 drives; USB 3.0: Softube Console 1 Mk3, Stream Deck XL; USB 2.0: SSL UC1, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; , M Audio Oxygen 49, Akai MPD218, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.32
labman
Post by labman »
bayswater wrote: Mon Sep 02, 2024 8:28 am
Hey Bays! Never noticed a massive hit, back when using it. We moved to using all the plugin alliance strips for that kinda thing in neve, API, SSL land and so aint been using it for quite a while now. So it may indeed be heavy at this point.
akr
Post by akr »
I really can't understand
Even when tracking with no plugins
Real time is at 50%
Even the mouse (track pad) seems to suffer and not moving normally, is shacking.
But it I switch to finder or other apps the system work as usual..... The mouse too
RMEff800
