Can't drag notes between tracks in 10.11!
Phil O
Re: Can't drag notes between tracks in 10.11!
Post by Phil O »
MLC,
Did you try it yet? Does it work on your system?
It does. It takes a second to highlight the track name section. Also works with option dragging.
csansom
Post by csansom »
Well thanks for the suggestion, Phil O, but after reading your description of the process I'm not even going to try that! Much simpler to select, then do the drag in the Tracks overview, as HCMarkus said (and which, as I said, I knew all along but had simply forgotten).
iMac Pro (2017), macOS 12.7.6 Monterey, MOTU M4, Adam A7 monitors, DP 11.3 94678, Finale 27.4.1.146, VIs from NI, SampleModeling, AudioModeling, Spitfire, Soniccouture, IK, UVI, Modartt, etc. Studiologic acuna88 keyboard
Phil O
Post by Phil O »
Well, I know some folks just prefer to stay in the SE, myself included. Glad you found a reasonable work-around. Let's hope 10.12 comes soon.
dix
Post by dix »
I can't really get Phil O's method to work consistently (but thanks Phil!). I succeeded a couple times, but it still only duplicated the data - it still leaves a copy of the MIDI notes behind rather than just moving it to the target track.
You might have to pause a moment in the left window and wait for it to highlight.
