Metal style drum sample replacement in DP 10
SMS
Re: Metal style drum sample replacement in DP 10
Post by SMS »
SLATE. TRIGGER. IT WORKS. TRY IT AND REPORT BACK.
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
dwilliams
Post by dwilliams »
rawrooo wrote:
dwilliams wrote:I don't bother exporting the MIDI. I just bounce it out. I haven't found that it needs time alignment. If you need to tweak the levels of the hits or move things around I guess I might try that. Probably, I would just adjust the egregious hits in the audio track and let Trigger run in real time and do it's thing. If you want, you can bounce the trigger performance as a new audio track and remove the plug-in. That might need some very slight time alignment. I don't know. Too many steps...
I hear that yeah. It seems like these kind of plugins work best in real time (as opposed to being bounced or exported as MIDI). Do you usually use the Slate samples or a capture from the session you’re mixing?
Really I’m just looking for a way to use my Toontrack libraries when doing sample replacement (to explain why I’m looking for that so adamantly). To do that I’m gona need MIDI notes.
Also this is kind of off topic but I’m often hearing new stuff thinking oh yeah there’s that obvious Slate snare I’m always hearing in videos about mixing on YouTube haha. Ofc who knows what was used. To be fair there’s a few Toontrack samples like are recognizable like that too.
I've not used custom samples but you can do. Supposedly, Trigger can handle 127 velocity layers (though their samples are like four or eight layers), each with up to 12 alternate hits. That's a lot of configuration but I might do it if I was working on an album. I almost never fully replace the real drum sound. I usually blend in the sample(s) which is easily accomplished in Trigger. Sometimes I will exaggerate what is good in the real drum sound, cut what I don't like and fill in the sound with sample(s). This can still yield a distinctive sound.
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 16" M3 Max 16-core 4.05 GHz 48GB 1TB Late 2023 MBP, Sonoma 14.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2, TB hub w/ USB 3.0 drives; USB 3.0: Softube Console 1 Mk3, Stream Deck XL; USB 2.0: SSL UC1, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; , M Audio Oxygen 49, Akai MPD218, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.32
