Did you try it on firewire?Nicolas Tochet wrote:Hello,
I did the Catalina update without paying attention to the possible problems of drivers. I use a MOTU ultralite MK3.
I read the recommendations (too late) and as I make a DJ set friday, I began to consider the downgrade... but I tested and in Ableton Live, the card is recognized and works !
(and this is not a recommendation to make the update, just for the dumb ones like me do some tests before making strong decisions)
Catalina compatible drivers posted
Re: Catalina compatible drivers posted
I can also verify that my good old firewire interface UltraLite mk3 works with 10.15.1.
CueMix does not come with the new installer and the old installed app is 32-bit so that is gone now.
CueMix features are of course available from UltraLite mk3 front panel but if anyone really would need those features then do not upgrade to Catalina. Dialing those knobs on the front panel is not too handy.
I am using the interface with MacBook Pro 11,3 (with Apple Thunderbolt2 to Firewire adapter) and all is well now.
I had an issue how to route audio from Wallander's NotePerformer plugin (hosted in Finale) to UL mk3 multiple audio outputs simultaneously. Ended up using Apple's AUNetSend & AUNetReceive plugins and Plogue Bidule as mixer. This setup still works in Catalina.
![Image](http://music.ee/imgz/bidule.jpg)
+372 56222285
Does this mean that if I upgrade to Catalina, my Track16 is recognized by LogicPro? Even without the drivers?
tks
tks
No.francesco wrote:Does this mean that if I upgrade to Catalina, my Track16 is recognized by LogicPro? Even without the drivers?
tks
+372 56222285
papageno wrote: No.
Why not? Is UltraLite mk3 different from track16? it is always hybrid
tks
viewtopic.php?f=2&t=66887&p=568206#p568204francesco wrote:papageno wrote: No.
tks
+372 56222285
Hy Everyone
I am about to upgrade to Catalina as I would like to use the latest versions of Logic Pro. I have an MTP AV and the question is: It will still work without problems with Catalina? Is there still a working driver to make it work in this OS? Or should I get rid of it?
Any advice is welcome, Thank you!
