That's for Seq view right? Yeah that's helpful, but I think the only thing is , we will have to assign another key as toggle start/stop.Maxxy wrote: As mentioned earlier, if in the regular Pointer tool mode simply click with the crosshair in the lower third of the audio waveform display or use Cntrl - click in a MIDI window to set the “selection” start point (or select a MIDI note in MIDI Edit window....or hold 'I')…. Now every hit of the Spacebar starts playback from that point... fast, relentless...
other way have the playhead return to starting play position
Re: other way have the playhead return to starting play posi
macbook pro 10.10, 2.5G,16G ram,256G SSD
I just saw this thread.
My technique: press Start in the memory bar’s Memory Start Time just under the main counter to “mark” your current wiper position, then press Auto Rewind. Now whenever you press Play, then Stop the wiper will return to its original position.
I use this all the time. It’s fast. If you’re looking for a precise location to split at counter for example then, with Auto Rewind still on, you can move your wiper position slightly and hit Start again in memory start time to re-mark your location.
