Bounce vs Real Time
williemyers
Re: Bounce vs Real Time
Post by williemyers »
groove wrote:...if what I'm listening is fine, then I know the file is.
Groove, how do you figure that? I mean, isn't listening in real-time like listening to the Input side of a tape machine? You still had to do real-time playback to be sure what was on the tape was good? (and you still have to do a real-time playback to be *sure* that the file is good?)
BTW, I'm in for BTD....when there are a dozen plus stems on a score with a dozen plus cues, bouncing MIDI tracks is a HUGE time saver. IT only kills me that I don't think VEPro5 ever got that sorted out?
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
supersonic
Post by supersonic »
This was a fairly simply mix with a around 10 audio tracks going to one master AUX that in turn was sent via another bus to a STEREO track for real time recording. Typically my song session will have around a dozen AUX busses for stems. A film might have even 30 of them, depending on how many different STEMS I will need in the end.
Music is movement in silence
groove
Post by groove »
groove wrote: Maybe I wasn't clear enough - apologies for my bad english - I should have said that the gain in time of BTD is small so I prefer to do real time. This gives me the opportunity to stop the recording if needs be. I've never said I just "watch" the wavefile for any problem and that I don't listen to the master file. I've used redundancy for lack a better word. Don't worry, I have more than my share of stems listening sessions before delivery to the re-recording house!
Most problems that occurs in a file are input related most of the time: random digital clips, skipped samples playback, etc. Real time recording still allows you to hear them and stop the recording. The other problem that can occurs is a corrputed file on the HD and even that you'll know right after the recording. Other reasons are related to limitations on some VIs and fx: for instance, Kontakt instruments with built-in delays fx sometime create artifacts on tempo changes in BTD. As I said, I never said I don't do real-time playback but I'm pretty confident that what I ear in real-time recording will be fine, hense what I wrote.
iMac Pro 3 GHz 10-Core Xeon E5, 64GB ram OS X 10.15.7, UA Apollo 8 Quad + Satellite Quad, UA 2192, Waves V12, LASS Full, VSL, Korg MS-20, Elektron A4, Moog SlimPhatty, NI Komplete13, ROLI, Soundtoys 5, Arturia V Collection, GForce Oddity, Serum.
Tritonemusic
Post by Tritonemusic »
Tritonemusic wrote:...(didn't notice which version you're using)
So sorry...I must have read your signature three times and just now noticed you're using DP 9.01.
:oops:
DP 10.13, OS 13.7.6, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
David Polich
Post by David Polich »
Real-time mixdown for me. Haven't done a BTD since 2002.
http://www.davepolich.com
buzzsmith
Post by buzzsmith »
williemyers wrote: BTW, I'm in for BTD....when there are a dozen plus stems on a score with a dozen plus cues, bouncing MIDI tracks is a HUGE time saver. IT only kills me that I don't think VEPro5 ever got that sorted out?
Wow...
This goes under:
1. I guess you CAN teach an old dog "new" tricks.
2. I should read the manual more often.
For years (and years), I have been freezing the MIDI VI tracks which is a real time procedure. On average about 3 1/2 minutes per track. Very time consuming.
Watching paint dry. :)
First thing this morning, I opened a project and tried the BTD on a couple of MIDI VI tracks. Takes about a 10th of the time!
Only thing I miss is the VU meter display to make sure that I'm not red-lining.
So glad I saw this thread.
(And, yes, I do real time mixes, too, unless it's just a quick run-off for a client.)
Merci...
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Actually your meters should still run but super fast.
When I first upgraded to an SSD, I was puzzled that BTD wasn't working. Well, it was but so fast I couldn't see the process.
I'm ok with that. :headbang:
supersonic
David Polich wrote:Real-time mixdown for me. Haven't done a BTD since 2002.
Any particular reasons David?
buzzsmith
Post by buzzsmith »
MIDI Life Crisis wrote:Actually your meters should still run but super fast.
I think I checked that, but I'll look again. I did see the Master Bus metering active.
Buzzy
Focal Twin6 Be(s)
williemyers
Wow...
Merci...
Buzzy
not at all! took me a few *years* to spot this - instant addiction!
~me
williemyers
correct (as usual!), MLC
~me
williemyers wrote:correct (as usual!), MLC
:rofl:
bongo_x
Post by bongo_x »
Did you zoom in and make sure they're aligned at the sample level?
Occasionally PT will bounce things just fine, but the file will be stamped 1 (or a few) samples off. I haven't seen that in DP, but what you're describing sounds like 2 files that are a sample off, you will only hear very high frequency content then as the lower stuff is still in phase enough to cancel out.
labman
Post by labman »
Been 100% realtime here for maybe a decade. I forget what the problem was with BTD. But I do recall we moved to realtime due to some kind of scary inconsistencies.
I would certainly try BTD again for stems if all is well with all plugs and VEP.
