No tails from SoundToys 5 when I hit Stop
tommymandel
Re: No tails from SoundToys 5 when I hit Stop
Post by tommymandel »
taka wrote:Oh I've discovered something--
... can be worked around if I insert something else before Echoboy(for example) in the aux bus. For example, if I insert ren EQ(with EQ off) inserted before Echoboy in my delay aux, the tail will carry on even if those Slate plugs on the audio track turn off after hitting stop..
Taka
Great tip! Thanks!!!
DP 11.32 12core(5,1): 64GB/10.14.6, two 24i/o's, two 2408mk3's, 4pre, MicroLite-- MBP 2015 16GB/ 2TB 'Blade SSD 10.14.4, Mainstage, Numa C2x, ReMOTE SL -- 32 Lives, Pro-53, SampleTron,Keyscape,MTronPro,RolCloud,Icarus,Dune,OB-E; Clearmountain Domain,Soundtoys,AdrenaLinnSync, LinnSequencers,Tempest, Montage, JU80, Sledge, Prophet-X, T8, OB-6 V-Synth, s70xs, D-50, TS-10, JD800, Karma, Pa-1x B3, Wurly, Mason Hamlin.
