Duplicate MIDI Notes
Re: Duplicate MIDI Notes
I had the same problem with my KeyStation Pro controller. Turns out I had overlapping zones turned on. I switched off all zones except one spanning the full 88 keys and the problem disappeared.
OS X 10.11.6 | DP 9.12 | 2.5 GHz 4 core iMac 2011 | 32 Gb RAM | Slave: 2x2.93 GHz Quad core Mac Pro 2009 | VEP 6 | VSL SE 1&4
- Primary DAW OS: Windows
Andrea's solution worked. Turning on 'Multi Record' under studio menu, and selecting one channel on the input of the MIDI track worked. For some reason, DP is detecting two Oxygen 61 MIDI In's as seen below.
I can't seem to delete one of the inputs from the Bundles menu. The Oxygen manual doesn't address setting ports either. Oh well, I guess the 'Multi Record' workaround will suffice.
Sorry to reinvent the wheel on this one.
DP9.5 64bit, Windows 10 Pro 64bit, UA Apollo Quad FireWire interface, Desktop: Intel i7 5820K at 4.0ghz, MSI X99A Gaming 7 mobo, 48gb RAM (DDR4 at 2133 mhz), MSI GTX 960 2GD5T 2GB, 512GB Samsung 950 Pro m.2 SSD (project/system drive). VEP 6
Does Audio MIDI Setup show more than one Oxygen 61?
+1. Exploration in this direction warranted.bayswater wrote:Does Audio MIDI Setup show more than one Oxygen 61?
ED: Ooops… Windows
Oops here too. Sorry. But there must be some Windows equivalent that will tell you whether the system is seeing two keyboard, and the physical unit it playing into both drivers.HCMarkus wrote:+1. Exploration in this direction warranted.bayswater wrote:Does Audio MIDI Setup show more than one Oxygen 61?
ED: Ooops… Windows
I wanted to give an update on this. I re-installed the driver for my Oxygen 61, now DP is successfully only seeing one input from the controller. Now I don't need to "Multi Record". However, my Oxygen 25 controller, which uses the same driver as the 61, still shows 2 inputs in DP. Very strange, but not a critical issue for me.
