I'll check that!
I'm traveling today, coming back on thursday, i'll check that for sure.
Please post the video about the cursor when you have a chance.
Thanks again shooshie, looking forward!
I also like the simple way Pro Tools does this, and the best alternative I've found in DP is setting the cursor where you want it, then using Control-Spacebar to start from that point. This also works if you drag through a selection area... it will start at the beginning of the selection.guitmac wrote:On this video on DP, the cursor comes back to the start point without having the auto rewind square under the cursor, so i guess there is a way to set this somewhere? I have tried all the options on the transport but no luck so far.....Thanks for the answer!
I'd be interested in watching this if you can shrink it down small enough for Youtube! This shorter video was great though.Shooshie wrote:I tried to cover all the ways you can automate the transport controls for playback and editing
Agreed. I use F5 to mark my selection start, and F6 for selection end, often on the fly as I playback so I can edit more musically than with the mouse. I don't remember if those are defaults, or if I set them up that way. (To guitmac: those would be the DP equivalent to Pro Tools Up and Down Arrow keys).Shooshie wrote:By the way, my preferred way of working is to use keyboard commands to set the start and stop points of memory
I don't get it... How would DP know when you want to use those commands without invoking the commands (or clicking something) ??guitmac wrote: Please let me know if I can get the layering and the "clip gain" on DP without having to do key commands every time.
Thank you very much for this video! I'm demoing DP8, coming from PT and this was one of the most annoying things to figure out. Your video made it easy for me to replicate PT's behaviour and explore the many other options DP8 provides.Shooshie wrote:Good answer, and the one I should have given last night instead of making a video about it. I tried to cover all the ways you can automate the transport controls for playback and editing. In the end, the video was just too long and way too large for YouTube, so I chopped it up and just used the part about linking playback and selection to memory.
If I figure out a way to reduce the rest to a reasonable size, I'll post it. Meanwhile, here's this:
Auto-rewind: Click to set Start Point, Click and Drag to set Range
Not as good as some I've done, but I didn't want to start over. This is just chopped down from 13 minutes to 2.
By the way, my preferred way of working is to use keyboard commands to set the start and stop points of memory, and to use the auto-rewind, auto-stop, and loop cycle to make the playback start, stop, and/or rewind where I want it to. When you're working, a click in the window will reset the range with the method in the video. That's not convenient; it's annoying. So, I just constantly reset the start point with a keyboard command as I move my work focus through the sequence.
And lastly, there are SO many ways of doing things in DP. It's kind of rare for it not to do something similar to the way other DAWs do it. I can think of a notorious one, Regions, but that's why it's notorious: it's one of the few cases where DP doesn't adopt those methods of working.
H.264 codec (via Quicktime)Shooshie wrote:So I'm trying to figure out how to get HD quality in much smaller video sizes. When I figure that out, I'll post more.
That's what I use! I don't understand why 13 minutes of video comes out at 900MB. As you might guess, I'm not a video guy.BKK-OZ wrote:H.264 codec (via Quicktime)Shooshie wrote:So I'm trying to figure out how to get HD quality in much smaller video sizes. When I figure that out, I'll post more.
