Memory usage starting at mid point
David Polich
Re: Memory usage starting at mid point
Post by David Polich »
chaim wrote:It is clear, that a project of a couple of VI's that [probably pushed the limits and] that I was able to work with, causing no problems at all regarding memory in DP7.24, I can no longer work with, using DP8.02 in 32 bit mode. It shows clearly that some thing has changed regarding memory.
I believe that is now a given.
The question is whether to use DP8 in 32-bit mode. For me the answer is no.
There is no advantage, and there are several disadvantages.
My primary holdout plug-ins are Sound Toys. I wish Sound Toys would get
their 64-bit act together.
http://www.davepolich.com
