Conductor's tempo changes won't change tempo.
Re: Conductor's tempo changes won't change tempo.
Did you all use the "Create Sequence With Selection" menu from the Sequence Editor's Mini-Menu? That's what made it happen for me. Copying in the Chunks Menu didn't have any such effect.
Shoosh
williemyers
Post by williemyers »
Dani, et al....this *may* contribute to a solution of your situation....
First off, I noticed that you're using Consolidated Windows - which I don't - so the followig may or may not help you. But here goes...
One of the things that's bothered me for some time about DP is that;
if you have a chunk (call it Seq. A) with the Conductor Track Event List window open, and you duplicate that chunk - creating Seq. B - then, make B the active chunk, the Conductor Track Event List window that you're seeing is still the one from A! And, of course, if you make edits in it, you're editing A's Conductor Track...not B's as you would think. And the kicker is that the Conductor Track Event List window doesn't show the name of the chunk that you're in , so you can spend an awful lot of time editing events in that window and not getting any results!
The fix is to close that window, then double-click B's Conductor Track and you'll get a new Conductor Track Event List window that works on B!
Like I said, if you're using Consolidated, none of this may help you, but worth taking a look at?
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
donadi
Post by donadi »
Thanks Willie,
Yes, I noticed that too in DP, I will try that trick and let you know.
Dani Donadi
MacPro OS10.9, Macbook Pro OS 10.10 DP9, Logic Pro X, Pro Tools 12, Cubase 8, Sibelius 8, Kontakt 5, all Sample Modeling,VEP5, EW Play, MSI, Multiple Libraries
Phil O
Post by Phil O »
Shooshie wrote:Did you all use the "Create Sequence With Selection" menu from the Sequence Editor's Mini-Menu?
Yes, I did when I tried this. But I didn't have the events window open. I'll give that a try and see if it makes a difference.
Phil
Phil O
Post by Phil O »
Nope, still working correctly in 7.24 (os 10.6.8 ).
Phil
Well, it was a bug in DP 8. MOTU has duplicated it and is working on it.
Shoosh
Caign
Post by Caign »
This post is very old now but the issue is still relevant, so I thought I would post a common solution to the problem "Conductor's tempo changes won't change tempo".
Tempo is obtained from one of a number of sources:
1. Conductor track
2. Tempo slider
3. Tap Pad
4. Remote control
To have the Conductor track control the tempo, ensure the tempo source is Conductor Track, set in the Sequence Tempo and Meter section of the Control Panel Window (i.e. the transport control area).
And of course insert tempo changes into the Conductor Track:
