Getting (some of) MLC's humor: One of the few good things about getting old.James Steele wrote:Madge?MIDI Life Crisis wrote:DP8? I'm soaking in it now...
http://www.youtube.com/watch?v=ndaZp0PI ... re=related
we see that and we dont even have to leave it idle for very long.Shooshie wrote: It starts out with a command or two, then after a while, most of the commands are not working. The keyboard commands just gradually quit working. It could be happening to you, but you don't notice it, since it could be commands that you don't use often.
I first noticed it when trying to resize the tracks in the Sequence Editor while holding down W to apply it to all of them. W didn't work. T didn't work. Then I needed to Select-All, which I then pare down to the tracks and range I want. Command-A didn't work!
It's 100% reliable on my system: leave it for a while, and the commands will always stop working.
Shoosh
Gotta say, the other "known issues" haven't gotten in the way of me and thousands of other people getting their work done, obviously.Stuartfox wrote:I'm frustrated with DP's reputation among people who don't know the software, but it will become harder to defend if these issues are here for a year or more as other known issues have been.
Well, the anti-DP folks have reared their ugly little heads over at GS now -
I've been doing my best to respond. Didn't take long for people there to
seize on the various comments in the Troubleshooting section.
I don't doubt you. That's why it's all the more perplexing that this doesn't happen to me at all.Gravity Jim wrote:I have spent a total of about one hour actually working in DP8, and have already had the keyboard go completely unresponsive once. Clicking on the Finder and coming back to DP didn't work: I had to quit and relaunch.
James Steele wrote:Gotta say, the other "known issues" haven't gotten in the way of me and thousands of other people getting their work done, obviously.Stuartfox wrote:I'm frustrated with DP's reputation among people who don't know the software, but it will become harder to defend if these issues are here for a year or more as other known issues have been.
And on this subject - I think the support / troubleshooting section should be for registered DP owners only - there could be some sort of verification, perhaps even MOTU would support it by allowing use of the serial number algorithm. Also would serve to stop pirates getting free support - something thats bound to become more of an issue with the windows version of DP imminent.Speaking of defending DP... here's a quote from Dave Polich in another thread on this board about GearSlutz discussion on DP:
Yep... some people just come here to dig up fodder for anti-DP diatribes.
I see it quite the opposite, If you are among the very few experiencing a particular problem, then it is likely something in your system that is the culprit. That could be bad RAM, a loose RAM stick, a graphics conflict, a misbehaving plug, a drive about to fail, a permissions problem. All these are NOT DP problems and if others aren't seeing what you're seeing, then it is not meant that YOU are at fault or that YOU'RE less significant.Stuartfox wrote:...I find it little insulting that any issues I have should be considered less important because I'm in the minority of people who experience them.
I understand the system variables that can contribute to these issues - and I'm not quick to blame the most obvious. I always try to eliminate everything methodically while troubleshooting, and I've managed to come up with information thats helped developers isolate, in some cases pretty major bugs in the past.MIDI Life Crisis wrote:I see it quite the opposite, If you are among the very few experiencing a particular problem, then it is likely something in your system that is the culprit. That could be bad RAM, a loose RAM stick, a graphics conflict, a misbehaving plug, a drive about to fail, a permissions problem. All these are NOT DP problems and if others aren't seeing what you're seeing, then it is not meant that YOU are at fault or that YOU'RE less significant.Stuartfox wrote:...I find it little insulting that any issues I have should be considered less important because I'm in the minority of people who experience them.
Don't have much "spare time" these days and I do use more audio tracks but obviously your number of chunks per project and number of VIs is atypical as you've said.Stuartfox wrote:.. with a VI track count of 100 - 150 and multiple chunks (for each cue) per project, I'm bound to unearth bugs that a singer songwriter who uses 20 tracks of audio in his / her spare time won't.
